Max Capacity Posted July 11, 2014 Share Posted July 11, 2014 Just a heads up, we should all check the bottom of the passenger side doors for rust that starts in behind the sealant under the door seal, down by the drain holes. I wire brushed mine last night and sprayed it with some Extend. Got it from NAPA. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
StkmltS Posted July 11, 2014 Share Posted July 11, 2014 I assume that's a common place in these cars for rust to start growing? Did you take a pic of where you're talking about? My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
Max Capacity Posted July 11, 2014 Author Share Posted July 11, 2014 No, just open the door and carefully run your hand on the very bottom or bend down and look behind the weather stripping. It's pretty obvious. My other doors are all fine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Zac88 Posted July 17, 2014 Share Posted July 17, 2014 mine is like that too. drivers 1/4 and above my windshield. Link to comment Share on other sites More sharing options...
