michael11 Posted June 8, 2012 Share Posted June 8, 2012 Ok.. so I have researched this, and can't figure out why my right cam gear has no timing mark!! The gear does not even have the edge where the mark would be. I do have the arrow, and I put it over another gear and come to the conclusion that the timing mark should be 7 teeth over. I have marked it and am going to give it a try.. Has anyone else seen this type of gear? http://img10.imageshack.us/img10/7049/img4129e.jpg' alt='img4129e.jpg'> Uploaded with ImageShack.us[/img] Thanks Link to comment Share on other sites More sharing options...
monkeyposeur Posted June 8, 2012 Share Posted June 8, 2012 Your right cam gear is marked correctly. See that white paint to the left of the arrow? That is where the hash mark is. It is exactly 7 teeth over from the arrow, the arrow being 1. Here is a pic of one of mine. edit: Your gear does look strange though. You don't have a flange that covers the teeth. I wonder if it is from an earlier 1.8L Subaru. Link to comment Share on other sites More sharing options...
michael11 Posted June 8, 2012 Author Share Posted June 8, 2012 Thanks for the reply... The other thing is... and maybe I am counting wrong.. But I can install the belt, and line up all the marks no problem, but the 44/40.5 tooth count is off.?I am counting from the crank gear outwards. Are you supposed to start at the next one over? As a matter of fact, I have the new oem belt here in my hands, and I still get a different count between the the 3 lines on the belt... Link to comment Share on other sites More sharing options...
monkeyposeur Posted June 9, 2012 Share Posted June 9, 2012 Here is the FSM diagram. Get it as close as you can. I had a hard time getting the tooth count when I was using an ebay belt, but when I used a Gates belt it lined up perfectly and easily. Link to comment Share on other sites More sharing options...
monkeyposeur Posted June 9, 2012 Share Posted June 9, 2012 Here are some pics of my Gates belt installed. Hope this helps. How far off are you? I have heard you can be a tooth or two (maybe three, but...) off and still be OK. Any more and that's not good. Link to comment Share on other sites More sharing options...
