06legsleeper Posted November 28, 2012 Share Posted November 28, 2012 well im going to do my pcv valve in a few weeks . but , my buddy runs a aos.. think he has the grimspeed oil cap one i was thinking aos or a catch can wondering if anyone else has done either of these. and is it worth doing . he swears by his . hes got a 08 sti... ive seen some write ups on them i was just wondering if peeps with the leggys had any input as well before i order my pcv stuff... im new to all this turbo stuff so i ask before i buy stuff that i dont know 100% about ... thanks in advance Link to comment Share on other sites More sharing options...
Strizzy Posted November 28, 2012 Share Posted November 28, 2012 No. My bad luck build Link to comment Share on other sites More sharing options...
Max Capacity Posted November 28, 2012 Share Posted November 28, 2012 No 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cypher0117 Posted November 28, 2012 Share Posted November 28, 2012 if you get the gs aos don't autocross your car. in short...no, they are probably not worth it. I have the crawford v2 in my car but I'm pretty sure all it did was put a hole in my wallet. Looks fancy though Link to comment Share on other sites More sharing options...
06legsleeper Posted November 28, 2012 Author Share Posted November 28, 2012 ok guess ill just get the pcv setup from fred beans. and call it a day then, lol Link to comment Share on other sites More sharing options...
grizzlyfarmer2 Posted March 22, 2013 Share Posted March 22, 2013 What is wrong with the GS AOS? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 22, 2013 Moderators Share Posted March 22, 2013 What is wrong with the GS AOS? vacuum issues of some sort causing loss of oil pressure under certain situations I believe... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
grizzlyfarmer2 Posted March 22, 2013 Share Posted March 22, 2013 Would you ever recommend one of these? Link to comment Share on other sites More sharing options...
kmoleg05 Posted April 16, 2013 Share Posted April 16, 2013 Just saying ALL of my hoses were hard and brittle so catch cans will be by route!! Link to comment Share on other sites More sharing options...
rob-2 Posted April 17, 2013 Share Posted April 17, 2013 Do PCV first. Changing mine may have resolved my oil burning on start up - time will tell. Link to comment Share on other sites More sharing options...
Aracheon Posted April 17, 2013 Share Posted April 17, 2013 I run a dual Moroso AOS setup on my car - one for the valve cover breathers, and one for the crankcase. The breather can doesn't catch a thing, whereby the crankcase can catches a marginal amount of mayonnaise and a fairly decent amount of water. (I attribute the water to the condensation I see a lot of this time of year.) Is it worth the money and effort spent? I suppose that depends on how much vapor your car is pushing through your PCV system, and how much you care if the engine ingests that shit or not. I was already elbows-deep in maintenance when I put my cans and check valves in, so it was more of a monetary investment for me than time. Link to comment Share on other sites More sharing options...
kmoleg05 Posted April 17, 2013 Share Posted April 17, 2013 ^^^^^ How did you run your check valves. You did not just run straight hose to the cans?? Link to comment Share on other sites More sharing options...
boxkita Posted April 17, 2013 Share Posted April 17, 2013 AOS are really only effective if you track your car. A GS AOS is a good way to hydro-lock your engine if you run on CCW tracks as the oil is forced out the passenger side of the engine and can't make its way back to the oil cap. On top of which, the oil cap can no longer be removed by hand (you need a 19mm wrench to remove the oil cap and a fine touch to put it back on without destroying the O-Ring). If you need an AOS, get the Crawford AOS v2 @ ~ $345. It deletes the PCV valve altogether. If you need a catch can, you can add it later. Keep in mind, you can still drain your engine of oil even with an AOS and/or catch cans. You still need to watch your oil levels. Especially, if you are tracking it (autox, rallyx, lapping (cw/ccw) ). YMMV. Proceed with Caution. Just 'cause you saw it on an Sti, doesn't make it right. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
rob-2 Posted April 17, 2013 Share Posted April 17, 2013 BTW I found a GS AOS clone for half the price. $159 http://www.speedelement.com/index.php?page=shop.product_details&flypage=shop.flypage&product_id=2980&option=com_virtuemart&Itemid=38 I'm considering running this if the oil problem of mine doesn't go away. Car never sees the track mind you. Link to comment Share on other sites More sharing options...
boxkita Posted April 18, 2013 Share Posted April 18, 2013 BTW I found a GS AOS clone for half the price. $159 http://www.speedelement.com/index.php?page=shop.product_details&flypage=shop.flypage&product_id=2980&option=com_virtuemart&Itemid=38 I'm considering running this if the oil problem of mine doesn't go away. Car never sees the track mind you. Not going to fix your problem. That track users have the most problems with the GS unit just means they drive their cars harder, not that they are the only ones having issues with it. others have tried it and removed it, even DD'ers. Having an oil problem and adding a part that is known to cause oiling issues is just asking for a blown engine. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
