Blue GT Posted March 19, 2008 Share Posted March 19, 2008 Just when you thought it was idiot proof I went a f***** it up: Connected everything as per a few of the install threads and went to power them up, nothing. No lows, no highs no fogs, only parking lights. I thought it must be the inline fuse....... nope fine then i thought maybe a missed a wire, nope everything is connected. Well so back to stock for me, i put one regular headlight back in tried to test and nothing! what the hell am i missing here? I pulled the headlights out completely and the support bracket wasn't back in when i tried to turn the stock setup back on, that doesn't make a difference right? Crap no i just want to have headlights till i can figure this out. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 19, 2008 Share Posted March 19, 2008 you plugged the headlight harness back in right? OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Blue GT Posted March 19, 2008 Author Share Posted March 19, 2008 Yes, thats actually what i checked first. Any chance i could have just blown something up? Fuse, Harness, Ballast something?? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 19, 2008 Share Posted March 19, 2008 possibly headlight fuse. check the fuse box under the dash. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
johndas Posted March 19, 2008 Share Posted March 19, 2008 Turn the key on? Sorry I had to say it! J Link to comment Share on other sites More sharing options...
Blue GT Posted March 19, 2008 Author Share Posted March 19, 2008 key is on, went back to regular bulbs and still nothing but parking lights. Checked both fuses under the dash and they both look fine. I'm going to replace them tomorrow with new ones to see if that does it. I cant imagine what i did wrong to cause this. Link to comment Share on other sites More sharing options...
johndas Posted March 19, 2008 Share Posted March 19, 2008 Eeeks...good luck with all of this...parking lights on is a good sign! DRL disable done? J Link to comment Share on other sites More sharing options...
mr_luv Posted March 19, 2008 Share Posted March 19, 2008 pos+ neg- correct? are you using grounding method and 12V source to power them are you going through harness Mr.350 Link to comment Share on other sites More sharing options...
RochNY91TSI Posted March 19, 2008 Share Posted March 19, 2008 Did you plug in *all* of the connections on the bulbs? I had that issue too and it was just that I had missed a connection Link to comment Share on other sites More sharing options...
itsme Posted March 19, 2008 Share Posted March 19, 2008 well if he has the battery harness then he only needs to plug 1 of the headlight headlight plugs to the battery harness. Then cover the plugs that are at the bulbs so they don't short out. What kit did you use? Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Blue GT Posted March 19, 2008 Author Share Posted March 19, 2008 DDM Kit from xenon expert, I do have the battery harness but both headlight plugs are plugged in. Link to comment Share on other sites More sharing options...
Livingtodie Posted March 19, 2008 Share Posted March 19, 2008 Your main headlight fuse should be under hood not under dash, big black square fuses. Link to comment Share on other sites More sharing options...
Blue GT Posted March 19, 2008 Author Share Posted March 19, 2008 ^Thank you sir I shall try that in a moment. Link to comment Share on other sites More sharing options...
Blue GT Posted March 19, 2008 Author Share Posted March 19, 2008 Well thats what i blew dont i feel like an idiot............. Thanks guys for all the help. Link to comment Share on other sites More sharing options...
Blue GT Posted March 21, 2008 Author Share Posted March 21, 2008 So i found what caused the fuse to blow; One of the plugs on the harness had the pos and neg swapped around so the leads coming off the stock wiring were grounding out. Causing the problem, i switched it and they are now good to go. Link to comment Share on other sites More sharing options...
Livingtodie Posted March 21, 2008 Share Posted March 21, 2008 Glad we could help you out. where in maine are you? Link to comment Share on other sites More sharing options...
Blue GT Posted March 23, 2008 Author Share Posted March 23, 2008 Brunswick, not to far from you, my GF is in grad school at UMaine Link to comment Share on other sites More sharing options...
