xt2005bonbon Posted June 11, 2012 Share Posted June 11, 2012 Though I am planning to do a compression+leak down tests for my car due to what happened to us a while ago (see here), is it possible to have compression/leak issues with all the following conditions met: 1. 25.5 MPG fuel economy highway 2. hitting 13.6 psi max on stock tune/turbo 3. no idling issues 4. no problem starting the car 5. apparently no weird sounds. Just the regular subie tick. 6. Car appears to pull the same as always. 7. No noticeable excessive oil consumption Interested to see what you guys think. Link to comment Share on other sites More sharing options...
bmx045 Posted June 11, 2012 Share Posted June 11, 2012 i do know of a friend who had 90psi in 1 cyl and the car operated fine with no hiccups. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 11, 2012 Author Share Posted June 11, 2012 i do know of a friend who had 90psi in 1 cyl and the car operated fine with no hiccups. Awesome. . Link to comment Share on other sites More sharing options...
bmx045 Posted June 11, 2012 Share Posted June 11, 2012 you're probably fine Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 11, 2012 Author Share Posted June 11, 2012 you're probably fine That's what I like to hear instead . On a serious note though, there must be some symptoms that one could track or notice. Would any logging parameters such as timing advance, etc... would act a bit funny? Link to comment Share on other sites More sharing options...
bmx045 Posted June 11, 2012 Share Posted June 11, 2012 you could log roughness, as valve issues can respresent misfires Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 11, 2012 Author Share Posted June 11, 2012 edited first post. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 20, 2012 Author Share Posted June 20, 2012 bump for some more feedback. I'd have to admit that my subie tick is pretty loud, to my taste, when engine is cold and under load below 1200 rpms. I need and will post a sound clip of it. I've only noticed it now that it is warm where we live and I can put the windows down. Have never put the windows down for the two previous years... Link to comment Share on other sites More sharing options...
bmx045 Posted June 20, 2012 Share Posted June 20, 2012 prolly cracked ringland and burnt valve Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 20, 2012 Author Share Posted June 20, 2012 prolly cracked ringland and burnt valve ^ Seriously though, can a cracked ringland and/or burnt valve still have the engine meet all the conditions mentioned above? I don't want to have to carry a spare shortblock in my trunk if you know what I mean . Link to comment Share on other sites More sharing options...
bmx045 Posted June 20, 2012 Share Posted June 20, 2012 Nothing you mentioned seems abnormal. The only other way to tell is if you actually do the leakdown test. So, do the leakdown test, that'll answer your OP Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 19, 2013 Author Share Posted January 19, 2013 Though I am planning to do a compression+leak down tests for my car due to what happened to us a while ago, is it possible to have compression/leak issues with all the following conditions met: 1. 25.5 MPG fuel economy highway 2. hitting 13.6 psi max on stock tune/turbo 3. no idling issues 4. no problem starting the car 5. apparently no weird sounds. Just the regular subie tick. 6. Car appears to pull the same as always. 7. No noticeable excessive oil consumption Interested to see what you guys think. Reviving my old thread . Well, about 10000 miles after this happened to me, the above list no longer holds true . All seven points are still fine except 3. I am getting idling issues with misfires. Got 2 misfires on 4 so far while idling (after driving the car for 5mn). And today, I even got a pending misfire code for cylinder 2 but it never popped. I kept driving with the CEL on and still got full power. I still have not done compression/leakdown tests yet. I will do it for sure as soon as I can. In any case, why do you all think I am getting these misfires? Remember that all 7 points still hold true except point 3. Note that I've been getting these misfires and rough idling in cold and damp weather conditions (35-50F and 80% humidity). Could be 1. injectors (don't think so) 2. spark plugs (don't think so) 3. coil packs (don't think so) 3. broken ringland (maybe but I am 'only' burning a quart of oil per OCI) 4. valves (could be especially knowing that my TB tensioner failed as I was driving) 5. o-rings at the intake to TGV's (maybe--I kina hope so) Note that rough idle mostly occurs within the first 15mn of a given drive. After a while, it appears to be fine. Link to comment Share on other sites More sharing options...
Oregon OBXT Posted January 19, 2013 Share Posted January 19, 2013 Swap injectors and plugs from known good to suspected bad and see if problem travels. Once you've done it a few times this is maybe 30 min project. But heck, as long as the plugs are out, thread in a compression gauge. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 19, 2013 Author Share Posted January 19, 2013 When I do the compression test, I am also planning to change all spark plugs (60K service). You're still thinking to swap injectors even though there was a pending misfire on #2? Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted January 19, 2013 I Donated Share Posted January 19, 2013 All ct08specb about his rough isle, it just got fixed by a dealer under warranty. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 26, 2013 Author Share Posted January 26, 2013 I've decided today (instead of doing a swap) to change my injector on #4 since I had a brand new OEM one already. Here is some close-up pics of the old injector. What do you guys think? Is this considered dirty? btw, I've gone for a 35 mile drive (mixture of highway and city traffic). So far so good. No CEL. The cold idle was not that great. But then again, the ECU was reset. When warm, idle appeared fine. Car is pulling pretty good in any gear. Next, I plan to change all my spark plugs since it is time. NOTE: click on the pictures to see them full-size. Link to comment Share on other sites More sharing options...
Oregon OBXT Posted January 27, 2013 Share Posted January 27, 2013 That's more dirty than the one of mine that failed... Almost looks corroded on the end. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 27, 2013 Author Share Posted January 27, 2013 really? I have to say that my white balance settings on my camera were on 'warm' (5000k). So it may look like rust but looks more like dirt to me. I need to check the net for pictures of dirty injectors to compare with. Drove an extra 30 miles. So far so good. I think I am done with el cheapo gasoline (from supermarkets). Link to comment Share on other sites More sharing options...
Oregon OBXT Posted January 27, 2013 Share Posted January 27, 2013 I thought I had a picture of it 'dirty' but the only one I have is after it was cleaned. Wasn't that much of a change. Since you already have a new one you know what they look like but I thought I'd post this up for others to see the difference between clean and dirty. http://legacygt.com/forums/picture.php?albumid=1534&pictureid=7886 http://legacygt.com/forums/picture.php?albumid=1534&pictureid=7887 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 27, 2013 Author Share Posted January 27, 2013 The end tip really looks shiny on yours. Link to comment Share on other sites More sharing options...
Oregon OBXT Posted January 28, 2013 Share Posted January 28, 2013 The end tip really looks shiny on yours. Clean living and I eat my veggies. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 28, 2013 Author Share Posted January 28, 2013 I am actually now thinking that if #4 is indeed dirty, how are the other 3 doing? Where did you send yours for cleaning? Link to comment Share on other sites More sharing options...
Oregon OBXT Posted January 30, 2013 Share Posted January 30, 2013 I am actually now thinking that if #4 is indeed dirty, how are the other 3 doing? Where did you send yours for cleaning? Local NAPA has a ultrasonic cleaning station/flow bench. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 30, 2013 Author Share Posted January 30, 2013 Misfire came back while idling after being barely semi warm . Though when fully warmed up, my idle is pretty stable around 750 rpm with a bit of cabin shake but not too bad (I always had some 'cabin shake' since I've owned the car). Car responds well too when I push on it. So, basically I am . Until I can find a place to get a compression test, my next steps are change spark plugs and find some carb cleaner to spread on the intake manifold gasket area. And cross fingers that the rpm will fluctuate when I spray some . Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 30, 2013 Author Share Posted January 30, 2013 sounds like im gaskets. do the carb cleaner only when the car is symptomatic That's what I hope. If not, then I am toast. Link to comment Share on other sites More sharing options...
