SlingXShot Posted January 31, 2008 Share Posted January 31, 2008 ? Link to comment Share on other sites More sharing options...
hondas123 Posted January 31, 2008 Share Posted January 31, 2008 It goes faster - The Mortgage Man Link to comment Share on other sites More sharing options...
zhabodav Posted January 31, 2008 Share Posted January 31, 2008 only the spec b can use 87 and be teh fasterererer Link to comment Share on other sites More sharing options...
lilrabbit129 Posted January 31, 2008 Share Posted January 31, 2008 It spits it out. It then leaves in the night, never to be seen again. Link to comment Share on other sites More sharing options...
lawl Posted January 31, 2008 Share Posted January 31, 2008 It spits it out. It then leaves in the night, never to be seen again. and yet another victim of ninja prostitutes that don't swallow. car for sale. PM me! Link to comment Share on other sites More sharing options...
CA08LGT Posted January 31, 2008 Share Posted January 31, 2008 It gets 35+ MPG. Link to comment Share on other sites More sharing options...
CTlegacy06 Posted January 31, 2008 Share Posted January 31, 2008 it turns into a time machine, think flux capacitor. Link to comment Share on other sites More sharing options...
bsdzine Posted February 1, 2008 Share Posted February 1, 2008 when i got my car my dealer told me i could use 89 octane. i laughed, drained the tank with my dad and filled it back up with 91.... not sure what would happen, but i doubt it's anything healthy. brian Link to comment Share on other sites More sharing options...
sactojesse Posted February 1, 2008 Share Posted February 1, 2008 The LGT is designed to run 91 octane minimum. If you ran 87 octane, your knock sensor would detect detonation and retard your timing, resulting in less power, more unburned gas and possible formation of carbon deposits in your combustion chamber, all without eliminating entirely the prospect of piston or head damaging detonation. But why don't you try it, save some money in the short term, and report back to us with your results? Link to comment Share on other sites More sharing options...
edkwon Posted February 1, 2008 Share Posted February 1, 2008 Im still waiting for the usual ppl to chime in and say its perfectly safe to run 87. Link to comment Share on other sites More sharing options...
SLegacy99 Posted February 1, 2008 Share Posted February 1, 2008 Kittens cry. Link to comment Share on other sites More sharing options...
SLegacy99 Posted February 1, 2008 Share Posted February 1, 2008 Im still waiting for the usual ppl to chime in and say its perfectly safe to run 87.  Mine Does! Link to comment Share on other sites More sharing options...
johnAWD Posted February 1, 2008 Share Posted February 1, 2008 Lower octane == more prone to preignition/detonation. The ECU hears knock and pulls timing. If pulling timing doesn't fix the issue, the ECU will then pull boost. 87 octane == bad idea for a turbocharged motor. Burn the fuel which is recommended by the manufacturer of the vehicle. Or get yourself an 87 octane tune. It's perfectly safe to run 87 octane. If you can live with less power than the car is capable of making, and have your motor running in a sub-optimal mode. Link to comment Share on other sites More sharing options...
GTSpeed Posted February 1, 2008 Share Posted February 1, 2008 Knock...Knock... Who's There? Regular Unleaded Link to comment Share on other sites More sharing options...
one69chev Posted February 1, 2008 Share Posted February 1, 2008 the lack of octane will kill brain cells rendering the offending cheap ass driver mentally challenged..... Link to comment Share on other sites More sharing options...
johnAWD Posted February 1, 2008 Share Posted February 1, 2008 No need to insult the original poster. Â This topic has been covered in depth on this site. Use the search button... Link to comment Share on other sites More sharing options...
G.T.Subie Posted February 1, 2008 Share Posted February 1, 2008 Im still waiting for the usual ppl to chime in and say its perfectly safe to run 87. it's not Denial is your best friend Link to comment Share on other sites More sharing options...
700watts Posted February 1, 2008 Share Posted February 1, 2008 I asked my doggie the same question and u see what he did....... Link to comment Share on other sites More sharing options...
dr_sharp Posted February 1, 2008 Share Posted February 1, 2008 2 threads started within 10 minutes just to bait people... voteban now. lol Link to comment Share on other sites More sharing options...
spect2k Posted February 1, 2008 Share Posted February 1, 2008 People have posted numerous links about the necessity of using premium gas in a car that runs on it. I agree 100% and would never run 87 octane in my car, however, today, it is less of a problem than ever to do it according to the information links below. Just because it's not as bad as it used to be, doesn't mean it is good and should be done. If you can afford the car, afford the proper gas to put in it. Just because if your car is out of alignment doesn't mean you HAVE to get it fixed, but you SHOULD right? Otherwise you damage the suspension over time and kill your tires... Same principal here, just because you probably CAN put in 87 octane doesn't mean you should and then suffer the consequences that follow. http://www.usatoday.com/money/autos/2003-07-30-premiumgas_x.htm http://www.edmunds.com/advice/fueleconomy/articles/106293/article.html Link to comment Share on other sites More sharing options...
alain_desforges Posted February 1, 2008 Share Posted February 1, 2008 Regular unleaded may taste like pumpkin pie but I wouldn't know 'cause I'd never use the filthy mofo... Â You guys ever try adding an ounce or so of Acetone per tank? Link to comment Share on other sites More sharing options...
smokedoutv6 Posted February 2, 2008 Share Posted February 2, 2008 about 2 weeks when filling up before a couple hours of driving the gas guy puts 87 in when i asked for super. i wasnt taking a chance and made him give me a bottle of octane booster figuring it would balance out. rather be safe then sorry especially since it was his mistake. car actually felt real good with the booster, it may have been all in my head but it did feel a little more responsive? Link to comment Share on other sites More sharing options...
Beanboy Posted February 2, 2008 Share Posted February 2, 2008 "The key is to figure out whether premium gasoline is "required" or "recommended." If it is recommended then a driver could opt to use a lower grade of gas, if they were willing to accept slightly reduced performance and fuel economy." From one of those articles -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Beanboy Posted February 2, 2008 Share Posted February 2, 2008 Booster didn't bring octane level up that much. Probably 87.5 or something like that. All in your head. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
dragonman586 Posted February 2, 2008 Share Posted February 2, 2008 3-5 dollars more a tank or being able to use that 8k worh of difference between out cars? You decide. I own a 2.5i Link to comment Share on other sites More sharing options...
