Heticor Posted December 5, 2013 Share Posted December 5, 2013 According to the Owner’s manual , the amount of oil required for a 2.5 GT is 4 Liters, however if I put that amount the stick indicator does not show a full level rather than a low level, to get the level to the full mark I have to use 4.5 liter. Additionally the oil measure stick does not show the level even on the two sides, one side shows a full level meanwhile the other shows some way between the low and the full mark. This measure stick is not very easy to read. I wonder what the correct amount of oil? Link to comment Share on other sites More sharing options...
DonnyJagaru Posted December 5, 2013 Share Posted December 5, 2013 This sounds like a Mazda 2.5. I personally would top it off with the extra 500ml and average the two sides. Generally speaking if you measure the oil in a cold engine on level ground it'll be accurate. Except if its a Mazda 2.5 Link to comment Share on other sites More sharing options...
bluesuby Posted December 5, 2013 Share Posted December 5, 2013 I've always used 2.5 quarts, which is probably close to 4 litres. I have looked at the higher dipstick reading and judging from what comes out at oil change time, I'd say that's more correct than the low reading. Link to comment Share on other sites More sharing options...
Heticor Posted December 5, 2013 Author Share Posted December 5, 2013 2.5 quarts = 2.36 litter, 4.2 quart = 4 litters. if you are only using 2.5 quarts your car is starving for oil. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted December 6, 2013 Share Posted December 6, 2013 Its possible to over-think all this I reckon. Amazing that not all modern cars have an oil level check built-in. Perhaps the newer Subies do, but my '08 doesn't. Subaru seems to be somewhat trailing-edge when it comes to certain things found in other mainstream vehicles. Link to comment Share on other sites More sharing options...
bluesuby Posted December 6, 2013 Share Posted December 6, 2013 2.5 quarts = 2.36 litter, 4.2 quart = 4 litters. if you are only using 2.5 quarts your car is starving for oil. Sorry. I meant to write 4.5 quarts. Link to comment Share on other sites More sharing options...
Heticor Posted December 7, 2013 Author Share Posted December 7, 2013 well ,I use 4.76 quart or 4.5 liters.. the information on the owner manual appears to be not correct. Link to comment Share on other sites More sharing options...
