T_Altland27 Posted July 2, 2014 Share Posted July 2, 2014 Looking to do a short shifter in my 09 legacy 5m/t n/a is it possible to use the kartboy bushings and all that with like an eBay type short shifter? Also I know it really firms the shifts up but do I even need the bushings at all just some small things I'm thinking about and need other opinions about this Link to comment Share on other sites More sharing options...
Max Capacity Posted July 2, 2014 Share Posted July 2, 2014 The bushings will tighten it up, the STS will shorten the throw. FWIW, you want a heavy shifter. A lightweight shifter will not help as much, you need some mass in the shifter. Buy a name brand from a good vendor on here. You may a bit more but your getting a part they would put on there own car. Your east coast, contact Mike at http://www.AZPinstalls.com in NJ. Talk with him and get the right part the first time. Tell him who sent you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
T_Altland27 Posted July 2, 2014 Author Share Posted July 2, 2014 Ha ok thanks max Link to comment Share on other sites More sharing options...
