JDM projector wiring check
Hi, guys, i am ready to do the JDM projector conversion, and i am using DDM HID h1 kit for low beam, keep the high beam in the projector as it is.
i don't have plan for the driving light yet and need advice.
I made a lil wiring diagram to show you guys before actually doing it.
Any comments are welcomed. thanks
http://i210.photobucket.com/albums/bb14/vicdeng/Wiring.jpg?t=1294711432
You dont split the ground. The way the lights work it by grounding the bulb, so when you turn your high beams on you ground out the high beam. But your wiring diagram is correct, just power instead of ground.
Here is some pictures and a DIY for it
http://sl-i.net/FORUM/viewtopic.php?f=39&t=5941&hilit=projector+wiring
For the city light I wired it to my "DRL's," and no longer have my side markers (amber) light up besides for blinker. The JDM lights only have a 1156 bulb socket for the turn signals, only blink, so I used that instead of modifying my USDM socket.
Hope this helps. If you have any questions just ask
So what you mean is i don't need to share ground, just positive for high beam, and leave the ground for low beam. That means i don't need to split the ground and just leave the ground for low beam to use.
