jp71ss Posted November 5, 2014 Share Posted November 5, 2014 Ok, I have read till I am cross eyed and I still don't know exactly what to look for. I need a rear diff for a 97 GT 5 Sp. What cars are compatible and which ones are limited slip? Thanks Link to comment Share on other sites More sharing options...
johnegg Posted November 5, 2014 Share Posted November 5, 2014 I need a rear diff for a 97 GT 5 Sp.maybe, but if so, you should not be buying lottery tickets or be driving over the speed limit. you are one of the unluckiest people using the internet. the point is they do not fail often. so unless you drained the oil and metal chunks came out, you probably do not need a rear diff. of course ''want'' is a different thing entirely. the 97 GT 5 speed manual trans has a 4.11 final drive ratio. this is the same ratio as the lego L auto trans. also the same as any ej22 auto trans car 95 - 99. or any ej25 manual trans 96 - 99. as for limited slip, no VLSD rear diffs were offered in the late 90s in the legos or low end imprezas. i do not know about the WRX or the SVX. however the VLSD was standard in the 01-04 outback, (maybe GT) so any manual trans outback of that era will match your final drive ratio. (00 the vlsd was optional) you may have to swap the connection point for the drive shaft, but the unit will bolt in and work. so really, what makes you think you need a rear diff? Link to comment Share on other sites More sharing options...
jp71ss Posted November 5, 2014 Author Share Posted November 5, 2014 It is really noisy back there but I am going to look into the driveshaft too. The axles are really rusty going into the diff and it is fairly rusty too. I finally got this thing to run smooth after rebuilding the engine with the help of the adjustable idlers. Engine and trans sounds great, rear area sounds terrible. I'm also thinking about pulling the axles and see what it sounds like then. Link to comment Share on other sites More sharing options...
johnegg Posted November 5, 2014 Share Posted November 5, 2014 rear area sounds terrible. it is probably a wheel bearing. have some one ride in the back and listen for the noise. which side is louder? rear noise problems, in order from least common to more common: rear diff axles drive shaft wheel bearings exhaust heat shields (not usually heard as ''rear noise'') good luck. Link to comment Share on other sites More sharing options...
jp71ss Posted November 5, 2014 Author Share Posted November 5, 2014 I will look into it or post it for sale. Link to comment Share on other sites More sharing options...
