Dyno sheet & timeslip - cryotune'd BNR 16g - 339hp/360 ft lbs
Date: May 2016
Ambient Temp: 75deg
Elevation: 56xx'
Weather: Clear
Car: 2005 Subaru Legacy GT Limited
Miles on car/engine: 147,xxx
Tuner: Dave (cryotune)
Dyno Info: Superflow Dyno 1.22SAE
Transmission: 5speed
Gear: 3rd
Peak Horse Power at RPM: 339hp @ 5000rpm
Peak Torque at RPM: 360 ft lbs @ 4700rpm
Baseline hp/tq for a stock on same dyno: 180ish, Stage2 - 220ish hp
Target Boost: 20.6psi
Target AFR: 11.7
SAE Correction factor: 1.22
Fuel: e85
Drag time: 13.2 @ 106.5
Weight: 3520#
Engine/Power Modifications:
- BNR 16g/VF40 (evo3 variant)
- cryotune
- PTP turbo blanket
- One step colder plugs
- Full Race ELH headers
- Perrin turbo inlet
- Grimmspeed uppipe
- Crawford AOS
- ID1000s
- Cobb catted downpipe cut to 3in flange
- AVO mid/Y-pipe cut to 3in flange
- Grimmspeed 3-port EBCS
- Borla ProXS mufflers
- Stock intake and K&N filter
- Process West topmount
- Aeromotive fuel pump
- TGV deletes
Driveline Modifications: Southbend Stage3 daily clutch, WRX flywheel
Suspension Modifications: bushings and such, Group N motor mounts
Other Modifications: None
The overlay is the TGV deletes. For me they did nothing up top, but had about a 20 ft lb gain down low.
http://i85.photobucket.com/albums/k62/dil222/dyno%20comparison%20-%20Copy.jpg
http://i85.photobucket.com/albums/k62/dil222/132atimeslip.jpg
  • 3 weeks later...
Great results, congrat! I am hopeful my BNR billet 18G will perform just as well on E85
On e85 it should shine! Good luck! I had a noise, pulled things apart and found a crack in the wastegate seat, as well as many other cracks throughout the housing. Stay tuned for a new dyno chart. :)
I do happen to have that! Here's my overlay from 91 oct to e85. It doesn't show the numbers for 91, but you can see the difference was massive (close to 50hp).
http://i85.photobucket.com/albums/k62/dil222/20160504_112521.jpg
