SSpeed Posted July 25, 2015 Share Posted July 25, 2015 Have a question in to cryo too, but thought I'd ask here. I changed out my injectors to DW8xx, measured out to 920. I then loaded up the limp map. I'm trying to figure out if I have an injector problem or if just the limp map is that way. I only let it run for about a minute, but it seems like a shaky miss to me. Or are the limp maps just that unsmooth? I did pull the connector on the front driver side injector and that one is definitely working. I guess I could attempt to pull each one and see. I don't have an CELs. Link to comment Share on other sites More sharing options...
SSpeed Posted July 26, 2015 Author Share Posted July 26, 2015 Correction, I'm getting a: P0303 Cylinder 3 misfire detected Awesome that cylinder 3 is the one you have to take the dang coolant tank off for... Link to comment Share on other sites More sharing options...
SSpeed Posted July 26, 2015 Author Share Posted July 26, 2015 ****, one of the injectors is bad. I swapped positions and moved the misifiring injector to the easy to reach #2 position. Fired up the car, shaking idle, pulled the #2 connector and no change. I sent these injectors back to DW for cleaning and testing and they all tested fine. How can that one be dead? Link to comment Share on other sites More sharing options...
SSpeed Posted July 26, 2015 Author Share Posted July 26, 2015 Update: On a whim I started the car, then put a 1/2" socket extension on top of the injector and tapped it a couple times with a hammer, it magically started working. I don't know what I think about that. They did sit for almost 5 months since being tested... Link to comment Share on other sites More sharing options...
SSpeed Posted July 26, 2015 Author Share Posted July 26, 2015 Hmm, if I weren't on a limp map for tuning on Friday I'd run some Berryman's B12 through a tank, but don't want to have that in there for a tune. But also not sure I want to tune on an injector that I had to unstick? Link to comment Share on other sites More sharing options...
fahr_side Posted July 26, 2015 Share Posted July 26, 2015 I'd get them cleaned and checked again. I quite like the DW850 top-feeds. Pretty easy to dial in. Sent from my iPhone using Tapatalk Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
SSpeed Posted July 26, 2015 Author Share Posted July 26, 2015 These are DW850 side-feeds. It makes me awful nervous now. I wish I'd checked continuity before tapping it so I could see if it was electrical or a sticking problem. Link to comment Share on other sites More sharing options...
fahr_side Posted July 27, 2015 Share Posted July 27, 2015 Convert to top-feed? Sent from my iPhone using Tapatalk Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
SSpeed Posted July 27, 2015 Author Share Posted July 27, 2015 That's always an option, the $1000 entry fee is a little painful though. Link to comment Share on other sites More sharing options...
fahr_side Posted July 28, 2015 Share Posted July 28, 2015 Cheap compared to popping a motor though... Sent from my iPhone using Tapatalk Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
ragman Posted August 4, 2015 Share Posted August 4, 2015 Scott, you got tuned last week, what was the outcome on this injector? Link to comment Share on other sites More sharing options...
SSpeed Posted August 4, 2015 Author Share Posted August 4, 2015 So far the injector is fine. After talking with DW they were confident it was stuck from sitting so long, so I went with that. I have 145k on the motor now, I don't want it to pop obviously, but if it does it's had a good life. Link to comment Share on other sites More sharing options...
