imfamousG Posted March 26, 2012 Share Posted March 26, 2012 i have noticed when i start my car in the am and it is cold it makes this weird typr of clunking and i cant find it and figure out what it is anyone know? Link to comment Share on other sites More sharing options...
FJuan Posted March 26, 2012 Share Posted March 26, 2012 Possible CV joint going out. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
gyung Posted March 26, 2012 Share Posted March 26, 2012 ^ what he said. Link to comment Share on other sites More sharing options...
imfamousG Posted March 26, 2012 Author Share Posted March 26, 2012 how do i check that ? and the rubber isnt torn or anything on it so how can i asses if it is? Link to comment Share on other sites More sharing options...
imfamousG Posted March 26, 2012 Author Share Posted March 26, 2012 also is how hard is it to dyi and change it? Link to comment Share on other sites More sharing options...
FJuan Posted March 26, 2012 Share Posted March 26, 2012 The only way to determine if the CV joint is going, beside the clucking sound while turning, is by tearing it down. Once you have it apart you would look for signs like this in the pic. http://4.bp.blogspot.com/-I3_KuELO6x8/Tef95RTItVI/AAAAAAAAALM/X6upKxyD0H8/s1600/CV+joint+outer.jpg http://www.vwt4forum.co.uk/picture.php?albumid=1739&pictureid=10192 Yes the used CV Joint and shaft can be used as a core for a purchase of a new one. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
imfamousG Posted March 26, 2012 Author Share Posted March 26, 2012 how do i go about taking it off and taking it apart? and should i buy a rebuilt or brand new one? Link to comment Share on other sites More sharing options...
FJuan Posted March 26, 2012 Share Posted March 26, 2012 It's fairly easy to pull the axle out. Brake the center nut in the hub, disconnect the lower control arm from the hub. Slide the brake/hub off the axle spindle, then pull the otherside out of the tranny. Sometimes a small crowbar will help to pop it out. Follow this link to Youtube, there is a 16 set videos related to the removal of the axle and CV joint. [ame=http://www.youtube.com/watch?v=pYzJtSbUlpM&feature=list_related&playnext=1&list=SP121ED247B460FA7E]How to Replace a CV Joint : How to Remove a Ball Joint Stud - YouTube[/ame] My wife's balls are delicious. Link to comment Share on other sites More sharing options...
TbirdMan Posted March 27, 2012 Share Posted March 27, 2012 That isn't entirely true, the axle nut on my car was so tight that I couldent get it off myself, I tried a breaker bar with a 2ft cheater bar on it and put as much pressure as i could without breaking the breaker bar. I ended up taking it to a place that has a 1" impact, that did the trick. Link to comment Share on other sites More sharing options...
FJuan Posted March 27, 2012 Share Posted March 27, 2012 2ft cheater bar? I use a 3 - 4 foot floor jack bar and that does the trick every time. Of course is makes if easier if you pry up the tab on the center nut first. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
TbirdMan Posted March 27, 2012 Share Posted March 27, 2012 I pried the cap up first, and I brought my consideral mass to bear (350lb standing on the end of the bar) it would NOT budge. Certainly mine may have been the exception, but it CAN happen. Link to comment Share on other sites More sharing options...
imfamousG Posted March 28, 2012 Author Share Posted March 28, 2012 So u the best solution to just take it in too a shop and have them do it? Link to comment Share on other sites More sharing options...
