Need Advice on lowering! H&R Springs
DC_12
Im looking at purchasing some H&R Sport springs, the advertised drop amount from these is 1.3 inches in the front, and 1.4 in the back. Im looking to get a similar stance as the to pics below, will the 1.3-1.4 be enough or do i need to go lower? Ill post a few pics of my Legacy as she shits now. Thanks for any input! :cool:
Stance im looking to get
http://i79.photobucket.com/albums/j146/cookd/3D0391C2-EB6E-4C59-8E24-D8AD64BEAC88-362-00000018FF226774_zpsba0493e3.jpg
http://i79.photobucket.com/albums/j146/cookd/IMAG2598-1_zps499bcc9c.jpg
How my legacy sits now
http://i79.photobucket.com/albums/j146/cookd/PicsArt_1372045121600_zps8237a950.jpg
http://i79.photobucket.com/albums/j146/cookd/2013-03-11_16-01-32_13_zpsd4263ffe.jpg
http://i79.photobucket.com/albums/j146/cookd/PicsArt_1354735169019_zps4b5361ab.jpg
Easiest thing to do is measure your current wheel gap and go with a ruler and go down 1.3 inches. And see if that about where you want it to be.
There are a few varying factors in these pics. Wheel size, tire size, and how much shit is in the car.
But most of these pics are probably roughly about where your looking to end up.
If not cut some coils off. :lol:
Here's how my LGT sits on H&R's paired with konis. I also have a 1/4 inch spacer in the rear. The springs should be paired with aftermarket shocks like the konis...
Look perfect, can i buy and install just the springs tho?
Yep, you will achieve the same height whether on koni's or stock shocks since the koni's are built into the stock shock housings.
Okay cool. Id like to have them but i just dont have the extra money at the moment and cant stand how high my car rides. Does the same go for struts? Or do i have to buy after market ones
All you or your shop needs to do is swap out the stock spring with the H&R springs...in the future if you decide to go with the koni inserts here is the DIY install thread:
http://legacygt.com/forums/showthread.php/koni-shock-strut-epic-engineering-spring-install-145744.html?t=145744&highlight=koni
Good luck, your ride looks nice...
  • 4 months later...
