Islandborn's LGT Build Tracker
I realized I needed a thread to keep me straight on all the stuff I've done to my Legacy. I have actually used GTEASER's line up (thanks btw!) to guide me. I just can't have my wife find this...:lol:
2012 Black on Black Legacy GT Carbon Fiber Interior Trim - Ordered on Feb 09 '12, Received in April of '12.
ENGINE
AWDTuning Stage2 motor
  • New cases halves bored and honed
  • JE Forged Pistons
  • King Bearings
  • Manley H-Tuff Rods w/ARP 2000 Rod bolts
  • 2012 STi Crankshaft
IAG Machined heads
JE Headgaskets
NGK Iridium One Step Colder 2309 Spark plugs
GSC P-D Intake/Exhaust Valves 33mm (+1mm)
Gates Timing belt kit w/water pump
ARP Head Stud kit
2012 Sti Cams
11mm Sti Oil Pump
Injector Dynamics 1000 fuel injectors
Deatschwerks 300 Fuel Pump
Setrab Series 6 10 row TopMount Oil Cooler (TMIC location)
Tial Q Blow Off Valve - 11 PSI - Black
BNR 18G Turbo w/ported wastegate
IAG Billet Aluminum CNC Top Feed TGV Deletes
IAG V2 Top Feed Fuel Rails
FueLab Fuel Pressure Gauge
Custom FMIC
Speed Density
AEM Dry Filter
Crawford AOS
Grimmspeed EBC
AVO Catted DP
Custom midpipe (removed mid cat)
Invidia Q300 CBE
Hardrace front engine mount
Mazda RX8 Tokyo Roki oil filter
Motul 8100 X-cess oil 5W40
93 Octane & E85 maps
DRIVETRAIN
Clutch kit: ACT SB11 - HDSS
Clutch Damper Delete
Perrin 2015 WRX Shortthrow Shifter Adapter
Perrin 2015 WRX Shortthrow Shifter Stop
Perrin 2015 WRX Shifter Bushing
OEM STI Shortthrow Shifter
Cobb Blue Shift Knob
Motul Gear 300 Trans oil
SUSPENSION
ISC N1 Coilovers
ISC RCAs
Whiteline Strut Tower Bar
Whiteline 22mm Adj. RSB w/ Whiteline Swaybar Lateral Locks
Kartboy Endlinks
BRAKES
DBA 4000 T3 Rotors F&R
STI Brembo Calipers F&R
Hawk HPS 5.0 Brake Pads
Goodridge SS Brakelines
Motul RBF 600 Brake Fluid
WHEELS & TIRES
Enkei Raijin 18X8 Matte Black
Bridgestone Potenza S-04 Pole Position
GAUGES
Cobb AP V3
Defi Red Racer Boost Gauge
INTERIOR
Weather Tech Mats
Arkon Seat Rail Iphone Mount
Thinkware 350 dashcam hardwired
Uniden R3 radar/laser detector hardwired
DAMD blue stitch Steering Wheel
EXTERIOR
BaysonR V-Limited Front Lip
Debadged (except rear Subaru emblem)
Blacked-Out Headlight Casings
Rear Window Wing
Primitive Racing Skidplate
C-Mod Grill
Hella Horns
Prova Side Window Visors
Corazon CF Bonnet Scoop
LIGHTING
Sylvania Silverstar zXe
OEM Puddle Lights
Morimoto XB LED Fogs
Whew! Now I can refer back!
  • 8 months later...
  • 9 months later...
  • 4 months later...
  • 9 months later...
What kind of power did this put down?
E85 sits at 360 whp / 420 wtq - sorta have to wait till 3rd gear to access the power - my trans would pack up and walk away if I launched. However, in 5th and 6th gear, the pull of acceleration is incredibly erotic
93 sits at 320 whp / 350 wtq - just above normal tune numbers. I sat around 290-300 whp / 335-340 wtq
The best way to see a bunch of my tunes with the various turbos is via the Cobb Tuning Database.
https://www.cobbtuning.com/dyno-database/
In order to get to my car:
All shops - pick Cobb Plano
Select Make - Subaru (duh)
Select Model - Legacy 2.5GT
Years - 2012
Select Owner - McCaulley, Shane (the only one, and they added another "l".)
You can see the Stage 1 OTS, Protune (stock outside TMIC and CBE), BNR 18g, and the Steamspeed 20g. My present tune was done by AWDTuning hence why its not there.
I do have a nice vid Cobb took on that first Protune:
https://www.youtube.com/watch?v=IWpIu5uAhx0
In the vid is Calvin Dotson who did all my tuning at Cobb. He now is out on his own tuning. Here is his website. He's brilliant.
https://www.dotsontuning.com/
