nickb98c Posted September 3, 2009 Share Posted September 3, 2009 I just cant bring myself to spend 270 to 290 on a K&N short ram intake. So instead I tossed around the idea of building my own system, using an AVO or K&N filter mounted to an MAF tube, and then elbows to the induction pipe. That way, I could place the actual filter farther away from the engine, but not all the way in the bumper. Any thing I should watch out for? Any feedback would be great too. Like I said, Just an idea. Link to comment Share on other sites More sharing options...
drsnobiz Posted September 9, 2009 Share Posted September 9, 2009 What about the MAF sensor? Where you gonna put that in? I've got an AVO MAF hose and have been contemplating the same. Do they make a short tube that's sole purpose is to house the MAF sensor? Link to comment Share on other sites More sharing options...
testes1010 Posted September 9, 2009 Share Posted September 9, 2009 Contact Matt at http://www.KSTech.biz he fabricates quality intakes at a fraction of the cost of a K&N. I'm running a KSTech CAI, very happy with it. Link to comment Share on other sites More sharing options...
PhilT Posted September 9, 2009 Share Posted September 9, 2009 You have to be very careful with intakes on these cars. A badly designed intake will cause turbulence in the airflow and cause the MAF to believe less air is flowing than what actually is. The ECU will then reduce the fuel and you will end up running lean. The knock sensor will then start pulling timing and you will end up with less power than before. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
CasopoliS Posted September 9, 2009 Share Posted September 9, 2009 just use the stock intake, or pick up a K&N or AEM intake for cheap on the boards. Get a tune for whatever you do. Link to comment Share on other sites More sharing options...
nickb98c Posted September 10, 2009 Author Share Posted September 10, 2009 What about the MAF sensor? Where you gonna put that in? I've got an AVO MAF hose and have been contemplating the same. Do they make a short tube that's sole purpose is to house the MAF sensor? Yes they do have tubes to house the MAF. If you look hard enough, you can find them on the web. Link to comment Share on other sites More sharing options...
