Humble Ride Posted July 16, 2013 Share Posted July 16, 2013 My mind is blown away right now. info overload:spin:. i have a sever sqeeking and rattle when i go over pot holes and such at normal speeds in my 05 OB. shocks is what im thinking the problem is. but while im at it i want to improve my car's handling. been looking around and im really lost. anybody willing to direct me to any helpful posts here? + if anybody has any info on led tail lights, exhauste and sway bars? (i used to have a legacy wagon missing some of the handling) i don't mind reading an searching i just don't want to waste my life finding the right posts. so if any body knows of a good spot to look let me know. thanks Link to comment Share on other sites More sharing options...
Rhitter Posted July 16, 2013 Share Posted July 16, 2013 It's not here, but this is a great place to start: http://www.subaruoutback.org/forums/81-wheels-tires-brakes-suspension/28368-2005-2009-outback-suspension-faq.html Most of us are lowered on some sort of Legacy specific suspension with sway bars (Legacy GT sways fit the OB). Anything for a Legacy GT will fit on an Outback (you just lose the ride height, wheels might rub if you go low enough) SublimeJoe's is a great thread to see what you can do and read through his thought process for the changes he made. http://legacygt.com/forums/showthread.php/outback-xt-164214.html Those two threads will give you a good over view of what can be done. But really it's up to your goals: Keep outback ride height / slightly better handling - replace struts with KYB (it's an option in the first link) and Rear Sway bar. Improve handling all around: shocks/springs - Outback specific coilovers (BC/BR - scooby2.5 has them), Legacy GT take off suspension, Legacy Bilstein suspension, Koni, etc. Sway bars - get a rear one and the avo reinforcement bracket. The car feels so much better. My OBXT build Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 17, 2013 Share Posted July 17, 2013 OP, this is what I've done to my OBXT. Goal was to keep ride height while improving handling: change rear OEM endlinks to AVO adjustable endlinksinstalled a 20mm whiteline rear swaybarinstalled AVO reinforced swaybar bracketsinstalled rallitek overload springs for the rear end These mods have significantly improved the handling. Now, I have to take care of the front (swaybar+bushings, endlinks), LCA bushings too. Subaruoutback.org has plenty of info too. Link to comment Share on other sites More sharing options...
Humble Ride Posted July 17, 2013 Author Share Posted July 17, 2013 thanks for the info.... Link to comment Share on other sites More sharing options...
DiscoPete Posted July 19, 2013 Share Posted July 19, 2013 Have a look at this: http://legacygt.com/forums/showthread.php/ob-stock-oem-struts-replacement-192178.html Link to comment Share on other sites More sharing options...
