Rear strut install trouble
Having some trouble getting this last strut into place (rear left). Installed the other three with little to no problem. Im installing Bilstiens of a JDM BG wagon. Does any one have any pointer/ tricks? this is my first time doing a solo strut install. thanks guys!
what kind of problem are you having? getting the bolts all the way back up in there? hanging up on things below? i didnt have much trouble at all getting the rears in, just took a bit of patience and a few turns back and forth to wiggle them up.
i just did the rears today.took me 2hrs with rotating tires and removing inside rear seats..i suggest to loosen the bottom 2 bolts first,once that is done,loosen the top 3 bolts and than pop the 2 screw out of the strut.might have to wiggle them out.when installing u will have to place a jack under the rear rotor to slightly lift the wheel enough for the bottom bolt to line up with the lower hole of the strut
