Accessport Problem-Can't upload map on '05
I am going to post this on this section because it seems to get more activity...
I just picked up an accessport and I am trying to load a stage 2 map onto my car. The AP recognized the ECU on my car, a 2005.5 LGT, and I saved the current ECU info.
I then reset the ECU and got the big green "checkmark," that said reset was a success.
My problem occurs when I pick which map I want to install and it goes to the next screen. The AP has a screen of "TEST MODE" and tells me to connect the green plugs, which I already have connected.
http://i1102.photobucket.com/albums/g453/qsmgto13/2005%20Legacy%20GT/20130304_063846_zps7f42cf2e.jpg
What the heck is going on with this thing?
Thanks!
Can you cut the two yellow wires then try again. Then after the reflash unplug the green connectors like all of us do.
Looks like some one hacked the system to be able to change maps ?
I'm not good with that type stuff.
Engine Build - Click Here
I'm assuming the yellow wires come one, from each connector, if he connects them its the same as plugging in the two green connectors.
right ?
  • I Donated
This button can't be stock, right?
http://i1102.photobucket.com/albums/g453/qsmgto13/2005%20Legacy%20GT/20130304_140041_resized1_zps2b3429b0.jpg
That looks like the button and status LED from an Innovate LC-1 wideband O2.
Took the tape off of the wires. You think If I connect the red on again and plug the connectors in it should work correct?
http://i1102.photobucket.com/albums/g453/qsmgto13/2005%20Legacy%20GT/20130305_100436_resized_zpsfa164d3b.jpg
I can't view the photos here at work. I think you need to remove the 2 yellow wires from either end of the green connector wires.
In other words put it back like stock.
Have you been to Invatives site to see if you can get the wireing set up ?
I will disconnect the yellows and connect the red pieces when I get home.
