ScoobyDoo94 Posted September 23, 2013 Share Posted September 23, 2013 Just this morning while going to work like I always do, I was driving down to get on to the highway and noticed when hitting bumps there was a new strut squeak from the back of my car. I thought nothing more of it and pulled on to the small highway I always take to get to the interstate and noticed a constant clunking noise coming from the back of my car. Concerned, I slowed down. It was still there. 5 miles later I finally found a safe place to pull off the road. All the tires looked fine, none were low on air, etc... Everything looked normal. The rims were not hot either. Figuring it was just the road, I continued to try to go to work. When I merged onto the highway, the dreaded clunk came back. I put on my four ways and limped it at 40 mph to the next exit and limped it home (at that point maybe 10 miles) at hardly ever more than 20 mph. Some things I noticed: when under a pull like going up a hill and trying to maintain a constant speed, the clunking stops. When applying heavy braking, the noise seems to stop. It only seemed to clunk when the car was cruising or under light acceleration. The clunk happens when the vehicle is in or out of gear. Recent work to the car includes changing brake pads and painting the calipers and brackets. That job was finished on Saturday, I drove the car around town yesterday (dinner with the girlfriend and whatnot) and it never clunked and drove perfectly fine. The noise seems to have started just today. I feared it could be the center differential, but when I tested it (tight corner at very low speed) there was no issue, no clunks, nothing. The car behaved normally. The tires on the car have been on the car for quite some time. They are approaching due replacement, but otherwise seem fine. The front tires do look to have more tread left than the rear tires. I'm very concerned about this. I'm going to call a few local shops on my involuntary day off and see what it can be. Meanwhile, does anyone else have any suggestions or ideas? Link to comment Share on other sites More sharing options...
Scubaru03 Posted September 23, 2013 Share Posted September 23, 2013 Double check all your bolts from your recent brake job. Did you grease pins and contact points? Did you replace rotors and not readjust ebrake? That's where I'd start good luck. Link to comment Share on other sites More sharing options...
ScoobyDoo94 Posted September 23, 2013 Author Share Posted September 23, 2013 Once its light out I'll check the bolts. I made sure to grease everywhere that was necessary, had all the rotors turned, and readjusted the E-brake. To me its sounds more like a driveline thing, but I'm still very new to Subaru's AWD. Thanks! Link to comment Share on other sites More sharing options...
ScoobyDoo94 Posted September 23, 2013 Author Share Posted September 23, 2013 Only one bolt was slightly loose, it tightened maybe a quarter turn. The sound still persisted, but I realized it was actually on the front wheel. That wheel had loose lug nuts. Why? I most likely got distracted while tightening them and stupidly didn't re-check them. Thanks! I'm glad this didn't get any worse than what it had to. Link to comment Share on other sites More sharing options...
Polo08816 Posted September 25, 2013 Share Posted September 25, 2013 Only one bolt was slightly loose, it tightened maybe a quarter turn. The sound still persisted, but I realized it was actually on the front wheel. That wheel had loose lug nuts. Why? I most likely got distracted while tightening them and stupidly didn't re-check them. Thanks! I'm glad this didn't get any worse than what it had to. That happened to a friend and his pickup truck when we were down at Ft. Benning. About half a mile off post, it turned into the "lulz". Wheel fell off and it seemed like there were ball bearings all over the road. #winning just like this guy: http://youtu.be/jv4m41viy4I Link to comment Share on other sites More sharing options...
