Mine is a different brand, not sure I'd do it again. Mine has two ports. Got it from a GB on NASIOC, I believe ours are different then STI's.
http://i185.photobucket.com/albums/x40/92Si/DSCN4776.jpghttp://i185.photobucket.com/albums/x40/92Si/DSCN4779.jpg
Engine Build - Click Here
Grimmspeed AOS has show to be a bit of a faulty design, just FYI.
Was doing quite a bit of research and on Nasioc they were going back and forth debating which is best. Thanks Barmanbean...
Sent from my SCH-I535 using Tapatalk
  • Moderators
As far as I know, there's not too much of a debate anymore--under certain conditions (mostly track conditions) the GS unit seems to kill motors. You could argue for a lot of folks who don't track their cars that it's really a non issue, but why take the chance especially if you are looking at the current group buy that makes the prices pretty close to the same.
I'm also leaning towards the Crawford myself because it removes the PCV setup--I think the GS setup leaves it in place. I figure removing it is one less thing that can fail down the road.
Not currently in stock :(
done a ton of reading on this. I think you can also build a really great system with a two $30 ebay catch cans. There plenty of good DIY on how to turn those ebay cans into useful catches with the addition of steel mesh. The two can system and its logic is explained well here (eventually) as well as how the crawford AOS works:
http://www.iwsti.com/forums/2-5-liter-litre-factory-motor/146699-official-sti-engine-venting-o-separators-catch-cans-thread.html
