lgt & 2.5i brakes
subiebeast22
in was reading this forum
http://legacygt.com/forums/showthread.php/faq-subaru-legacy-2-5i-115322.html.
and it says how the brakes (calliper, rotor etc) are not a direct
replacement. What i was wondering was what needs to be done. The bolt
patterns are the same correct? so is it a matter of just buying bigger
rotors and new calipers. I was looking at a upgrading to a stop tech brake
kit
http://www.importimageracing.com/stoptech-slotted-rotors-f-r-for-05-legacy-gt.html. All i have to do is but new rotors and callipers correct?
i have an 06 2.5i with the stock 17" rim.
If you want to use those StopTech rotors made for the LGT, you will need:
- LGT calipers
- LGT caliper brackets (usually attached to the calipers)
- LGT brake lines (also usually attached)
- LGT specific brake pads
If you hear grinding or scraping after the installation, it's most likely the dust shield scraping against the rotor(s) since the rotors are larger, especially the fronts. Use some pliers to bend the dust shields back.
