ouch1011 Posted May 17, 2011 Share Posted May 17, 2011 Pulled it off yesterday to do some other work and noticed this. There are a couple of spots where it looks like the metal tabs have bent back a bit, but that is the worst, and it looks like the tank seal may be leaking slightly as well (oil seepage on that lower corner) Thoughts? Is it salvagable? Or should I be saving up for an upgrade? The car is basically stock with a mild stg 1 OS tune, peaks at 15psi. I have plans for more later, but wasn't planning on shelling out for a new IC this early. Link to comment Share on other sites More sharing options...
robinlsb Posted May 17, 2011 Share Posted May 17, 2011 Yes, your TMIC is coming apart. Search JB Weld for interim solution. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
gil_ong Posted May 18, 2011 Share Posted May 18, 2011 or see this. http://legacygt.com/forums/showthread.php/bulletproof-tmic-mod-lgt-08-wrx-158870.html?t=158870 Link to comment Share on other sites More sharing options...
Saul_Good Posted May 19, 2011 Share Posted May 19, 2011 ^^^ I have this mod. Its a very good solution and alternative to JB weld. Link to comment Share on other sites More sharing options...
