The_Josh Posted March 28, 2014 Share Posted March 28, 2014 I'm still trying to find a weird vibration in my car and i was checking out the transmission mount and its looks a little cockeyed. how does this unit function and is this normal or does it need to be replaced? http://i79.photobucket.com/albums/j124/chevelle02/blue%20Fin/IMG_20140328_123607_zpsocdy4jpb.jpg Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 28, 2014 Moderators Share Posted March 28, 2014 I'm having trouble seeing exactly what is going on there...what's the piece of rubber hanging around the nut there? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
The_Josh Posted March 28, 2014 Author Share Posted March 28, 2014 I'm having trouble seeing exactly what is going on there...what's the piece of rubber hanging around the nut there? that the center stud on the transmission mount, i believe its supposed to be flat against the metal (i feel the mount is collapsed but i don't know for sure) Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 29, 2014 Moderators Share Posted March 29, 2014 Interesting. manual trans? I think I have a whole transmission brace setup and transmission mount if you end up needing one. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
The_Josh Posted March 30, 2014 Author Share Posted March 30, 2014 Interesting. manual trans? I think I have a whole transmission brace setup and transmission mount if you end up needing one. Thank you but I ended up just picking it up at the dealer. I've been going there so much they just started discounting my parts. I picked up a new mount for $40 Sent from my Nexus 5 using Tapatalk Link to comment Share on other sites More sharing options...
discojon Posted March 31, 2014 Share Posted March 31, 2014 I just looked under my 5eat 06 and my trans mount looks just like yours and I have a vibration like you describe. From looking at the mount I think that bolt acts as a limiter but I'm not sure. I'd be curious to hear what others have to say or of a new mount fixes the vibe. Sent from my SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
CNY_Dave Posted March 31, 2014 Share Posted March 31, 2014 Needs a new rear trans mount (the rubber thing that bolts to the trans and crossmember). That bolt/snubber are supposed to be floating but not that much. Link to comment Share on other sites More sharing options...
D-VO Posted November 20, 2014 Share Posted November 20, 2014 Bumping this thread, I had the same issue. Thank you for the picture! 2005 5EAT Wagon. Went under the car to fix a pretty nasty exhaust leak and discovered an identical situation. My car will CLUNK over bumps once the chassis warmed up. I think that the rubber started to degrade on me and then got stretched when I pulled the engine up to remove / clean the oil pan and do spark plugs. Replacing the mount this weekend. Will report back. Link to comment Share on other sites More sharing options...
D-VO Posted November 26, 2014 Share Posted November 26, 2014 Reporting back: The correct 5EAT part number is 9560 on the mount. NOT 9552. This fixed the clunk I was having and the vibration I was feeling which I thought was differential / CV noise for a while. A+ maintenance task, would recommend to anyone with 100k miles on their car. Link to comment Share on other sites More sharing options...
