rexster Posted May 23, 2007 Share Posted May 23, 2007 i'm trying to find a local shop to do some welding for me and the closest guy can't weld stainless. anyone know for sure? Link to comment Share on other sites More sharing options...
Spec B Posted May 23, 2007 Share Posted May 23, 2007 Mufflers are stainless (per the midas guy) but the piping is not. Link to comment Share on other sites More sharing options...
bugblatterbeast Posted May 24, 2007 Share Posted May 24, 2007 my stock cans are rusting. if you want to check if they are stainless, just use a magnet. Link to comment Share on other sites More sharing options...
edmundu Posted May 24, 2007 Share Posted May 24, 2007 Oem's like to claim using SS as a marketing ploy, so they use the lowest grade they can getaway with, in this case it's likely 409. Most aftermarket SS exhausts use 304, and on some exhaust headers/manifolds, they'll use 321. Link to comment Share on other sites More sharing options...
rexster Posted May 24, 2007 Author Share Posted May 24, 2007 i think they are stainless because the piping is really rusted but the mufflers themselves are not. the magnet may or may not stick depending on the grade. apparently there's different equipment involved for welding stainless. i guess i'll bring one in and let the guy tell me if he can work with it. Link to comment Share on other sites More sharing options...
rao Posted May 24, 2007 Share Posted May 24, 2007 all you need is shielding gas and stainless filler rod - most muffler shops can easily handle stainless. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
bugblatterbeast Posted May 25, 2007 Share Posted May 25, 2007 if the hangers are not stainless, then there's no need to use stainless filler. just reverse the welding polarity and use flux core mild. it won't be pretty but it will hold, I've done a few this way. I'm not saying the weld will be the strongest, but we are not exactly talking about high loads here. Link to comment Share on other sites More sharing options...
bugblatterbeast Posted May 25, 2007 Share Posted May 25, 2007 Oem's like to claim using SS as a marketing ploy, so they use the lowest grade they can getaway with, in this case it's likely 409. Most aftermarket SS exhausts use 304, and on some exhaust headers/manifolds, they'll use 321. good point. I didn't think FHI would stoop so low. The price difference in raw materials (409 vs 304) isn't that much compared to the step up from mild. as for the tubing, I think they are worried about manufacturing yield. every time I've tried to bend stainless it has either split or kinked on me.... Link to comment Share on other sites More sharing options...
