d_jamont Posted April 9, 2011 Share Posted April 9, 2011 Gents, Does anyone have these injectors? AS I read the description it sounds like if you have sidefeeds (I have 05 OBXT) you can still run these injectors as they come with a conversion kit of some kind. What does the conversion kit include? How easy is the install? I was under the impression that it was your TGV housing that determined what style of injector you could use. ie to use top feeds, you had to trade out your TGV housings as well. Has anyone put these in yet? Cheers, Don Link to comment Share on other sites More sharing options...
Th3Franz Posted April 10, 2011 Share Posted April 10, 2011 A few of us are running these. I installed the new rails and injectors a couple months ago. The install is not too difficult.. just time consuming. You need to run new fuel lines with the new rails, since they are 6AN fittings. You have to remove the intake manifold to get the stock fuel hardware off. Best injector set up I've encountered though, and we've been tuning a number of cars. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
spec.B Dream Posted April 10, 2011 Share Posted April 10, 2011 Lots of great info in NSFW's thread: http://legacygt.com/forums/showthread.php/nsfws-id-1000-injector-swap-139738.html Link to comment Share on other sites More sharing options...
