The Official: Fastest Legacy Thread (1/4 and 1/8)
  • Replies 311
Posted Images
Best et and 60' last night. Still a bone stock automatic
1. Time slip required (actual picture of)
2. Must post in this fashion:
Event: track run
Loaction: name of the Track
Date: 08/11/2010
Ambient Temp: in F
Elevation: Google can help you with this
Weather: Rain? Snow? clear?
Car: year, make and model
Tuner: Name of person and shop
Track info:
Transmission: 5speed, 6speed, PPG, JDM, ect ect
Peak Horse Power at RPM: The RPM that you reached max HP
Peak Torque at RPM: The RPM you reached Max TQ
Fuel: Octane rating if pump, octane and brand if specialty fuel
Engine/Power Modifications: Anything that adds horsepower that you have added to your car. i.e. bigger turbo, intercooler, exhaust, injectors
Driveline Modifications: Stock/Upgraded clutch, light weight flywheel, upgraded drive shaft, upgraded rear or center diff.
Suspension Modifications: struts, springs, coilovers, braces, bushings, and other items that reduce body motion and increase power transfer to the ground
Other Modifications: weight removal, addition of a roll cage, lighter wheels or rotors, smaller than OE diameter tires, and other items that affect vehicle weight, rotational inertia, and power delivered to the contact patch
Picture of Dyno Plot and AFR/Boost Plot: Ask your tuner for this or copy it from your tuning software
Need forum help? Private Message legGTLT
Sorry here u go
Event: Test n Tune Location: Cecil County Dragway
Date: 11-16-12
Ambient Temp: 40
Elevation: 320ft
Weather: Clear
Car: 2008 LGT
Tuner: None
Track info: 1916 Theodore Road Rising Sun, Maryland 21911
Transmission: 5EAT
Peak Horse Power at RPM: Unknown
Peak Torque at RPM: Unknown
Fuel: 93 oct
Engine/Power Modifications: K&N Air Filter
Driveline Modifications: None
Suspension Modifications: None
Other Modifications: Aftermarket Wheels on All Season 215/45/17 Tires
Car # 4080
http://i1103.photobucket.com/albums/g470/0ngbak/1320.pnghttp://i1103.photobucket.com/albums/g470/0ngbak/ongslgt.png
Event: Fun Day
Loaction: Rock Falls Raceway
Date: 09/29/2012
Tires: NT05 235/40/17, street tires
Ambient Temp: 75 F
Elevation: 838 feet
Weather: Sunny Hot
Car: 05 LGT
Tuner: Nuke of NF Performance
Track info: 1/4 Drag Strip
Transmission: 5 speed
Peak Horse Power at RPM: 300+
Peak Torque at RPM: 300+
Fuel: E85
Engine/Power Modifications: supporting mods
Driveline Modifications: ACT 6 Puck Sprung
Suspension Modifications: Progress springs kyb struts
Other Modifications: Full interior
Edited by O_vang
Add info
Event: track run
Date: 08/11/2010
Ambient Temp: in F
Track info:
Timeslip:
http://i.imgur.com/0SYoy.jpg
Dyno graph:
http://i.imgur.com/Qqtng.jpg
Porn:
http://i.imgur.com/y7UrK.jpg
Event: Hi-Tech Oils Race 4 Real Wednesday
Date: 03/10/2012
Ambient Temp: 18C (64F)
Elevation: 70m above sea level (230ft)
Weather: Clear sky
Car: 2007 Subary Liberty GT-B STi
Tuner: Insight Motorsports
Track info: 1/4 mile drag strip: http://sydneydragway.com.au/
Transmission: 5EAT
Peak Horse Power at RPM: 208.9kw @ 5700rpm (280hp)
Fuel: 98RON
Engine/Power Modifications: Tomei ARMS M7960, Plasmaman FMIC, APEXI CAI, Greddy Trust RZ BOV, HKS EVC5, SARD Fuel pump + reg, ID1000 injectors, Custom 3" dump pipe into K2 Gear Spec-neo Ti dual catback exhaust.
Suspension Modifications: Cusco Zero 2-E coilovers, STi front strut brace, STi front lower arm bar, cusco front swaybar and endlinks, cusco front h-brace, cusco transmission tunnel support, cusco floor braces, cusco rear swaybar and heavy duty sway bar mounts, cusco 4 piece rear under brace set, cusco rear strut brace, cusco brake stopper, cusco radiator brace, j-speed front lower arm bushes.
Other Modifications: Prova air guide, cusco oil catch-can, defi cr oil pressure and boost gauges, innovate wideband o2 sensor, various cosmetic upgrades
Recently retuned on E-85 and netted a substantial power increase and tuner made it shift a lot quicker...heading back to the drags to see what it can get :)
Nice looking car man. What all u have to do to swap to E85?
Timeslip:
Date: 03/10/2012
Weather: Clear sky
Transmission: 5EAT
Fuel: 98RON
All I needed was a retune :) you just need bigger injectors, larger fuel pump and preferably a fuel regulator, all of which I had installed before my initial pump fuel tune.
I got 237kw atw (320ish hp) but that was on pump E-flex which is only E70 and still had a quarter of a tank of regular fuel in it so I recon true figure is now somewhere around 250 kw or 330ish hp...as I said tuner has the car shifting quicker so really excited to see what I can manage at the strip now! Will be going this Wednesday if the weather holds up!
Took it for another run after switching to ethanol. I use E-flex which is available at the bowser and is about E71. Ran 12.53 @ 112.95 mph last night.
Timeslip:
http://s11.postimage.org/wyy9xy2sj/12_and_a_half_pass.jpg
Dyno graph:
http://i.imgur.com/Uk83K.jpg
More Porn:
http://i.imgur.com/o1J8e.jpg
Date: 12/12/2012
Ambient Temp: 21C (70F)
Weather: Clear sky
Tuner: Matt (throttlehappy) from KiDo Tuning
Transmission: 5EAT
Peak Horse Power at RPM: 237kw (322hp)
Fuel: E-flex (E71)
Had an issue shifting it into 2nd, 1st gear over-revs and even if I try to manually shift the auto it still hits the rev limiter and cuts power for a split second. I think this is costing me some good time as my half track time is similar to previously, but it is putting on an extra 10mph in the second half of the track compared to previously!
  • 2 months later...
Left lane and backed it up with another 14.1 pass. Spiked 17.5lbs of boost last night
Event: Test n Tune
Date: 3-2-13
Ambient Temp: 42
Elevation: 320ft
Weather: Cloudy with occasional flurries
Car: 2008 LGT
Tuner: Cobb AP Stage 1
Transmission: 5EAT
Fuel: 93 oct
Engine/Power Modifications: K&N Air Filter,
Driveline Modifications: Nameless Performance Muffler Deletes
Event: Test n Tune
Date: 3-2-13
Ambient Temp: 42
Elevation: 320ft
Car: 2008 LGT
Transmission: 5EAT
Fuel: 93 oct
I should be there on Friday, but it will be around 8:30 or 9. i want to get a stock run since i got rid of my dp and ap.
Event: Grudge Racing
Date: 3-16-2013
Temp: 48*
Elevation: 320ft
Weather: Cool/Night
Car: 2008 Legacy 2.5GT
Tuner: none
Track Info: 1916 Theodore Rd Rising Sun, MD 21911
Transmission: 5mt
Horsepower: 243 (stock)
Torque: 243? (stock)
Fuel: 93 oct
Mods: none
Suspension: H&R Lowering Springs
Other: Removed the spare tire (-45lbs)
i believe this makes my time the fastest stock lgt.
Edited by Brett
added detailed info
^Nice, all stock?
That's what i was getting stage 3, faster to the 1/8 but 4th gear had no more power and was trapping only 96-101mph:confused: Was like hitting a wall, but the tune was crap and the fuel pump just couldn't keep up. All is better now and will give it another run next month. Mid-high 12s:)
What rpm did you launch it?
^Nice, all stock?
swear to god, all stock, besides lowering springs. i don't even know what rpm i launched at, but the launch and shifts were perfect. i eased out on the clutch to where it would start to catch, then as soon as the tree started lighting up, i floored it, then launched when it was green. when i was stage 2, that's all i ran, so i honestly don't know how i pulled this off. i even trapped higher
