DadMod Posted December 28, 2017 Share Posted December 28, 2017 Has anyone installed the AVO Power Air Filter Kit (SUX01G42BKITT), link below, on a 5th gen LGT? http://www.avoturboworld.com/catalog/product_info.php/products_id/48 I know the general consensus is that I probably don't NEED an intake, but that doesn't mean I don't WANT an intake. If anyone has experience with this, was it a pretty straightforward install, or were there issues? Link to comment Share on other sites More sharing options...
FLlegacy Posted December 28, 2017 Share Posted December 28, 2017 Has anyone installed the AVO Power Air Filter Kit (SUX01G42BKITT), link below, on a 5th gen LGT? http://www.avoturboworld.com/catalog/product_info.php/products_id/48 I know the general consensus is that I probably don't NEED an intake, but that doesn't mean I don't WANT an intake. If anyone has experience with this, was it a pretty straightforward install, or were there issues?It won't fit. All the applicable models have the intake tube going toward the fender. Our GT has the intake tube coming from the fender. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
Shadow_419 Posted December 29, 2017 Share Posted December 29, 2017 It won't fit. All the applicable models have the intake tube going toward the fender. Our GT has the intake tube coming from the fender. Sent from my SAMSUNG-SM-G920A using Tapatalk The intake does go towards the fender I'm not sure why you say it's coming from. I don't see why you couldn't make it fit as long as the maf sensor fits the tube opening. Now getting it to work properly is a whole different story. May look "cooler" but could increase the air temperature coming into the turbo. Link to comment Share on other sites More sharing options...
cww516 Posted December 29, 2017 Share Posted December 29, 2017 On the models that's meant to fit, the intake tube runs forward along the block and hooks over toward the fender, whereas ours comes up the fender and hooks out toward the center of the car. You could probably plug that MAF housing into the flexy hose that connects to the airbox, but you're still faced with the issue of sucking in hotter air. Link to comment Share on other sites More sharing options...
FLlegacy Posted December 29, 2017 Share Posted December 29, 2017 The intake does go towards the fender I'm not sure why you say it's coming from. I don't see why you couldn't make it fit as long as the maf sensor fits the tube opening. Now getting it to work properly is a whole different story. May look "cooler" but could increase the air temperature coming into the turbo. Weird I certainly don't remember my intake being routed like this one...this whole time we could have been using 4th gen parts. For clarity I added a yellow arrow to show the intake tube and orange arrow to show the direction of airflow. Link to comment Share on other sites More sharing options...
Shadow_419 Posted December 29, 2017 Share Posted December 29, 2017 I know it's not routed like 4th Gen but the intake goes towards the fender and the loops down to the turbo. It would not be able to be mounted exactly the same but you could definitely get it to fit. Still stuck with hotter air and probably poorer performance or a wash if you're lucky. Link to comment Share on other sites More sharing options...
FLlegacy Posted December 29, 2017 Share Posted December 29, 2017 I know it's not routed like 4th Gen but the intake goes towards the fender and the loops down to the turbo. It would not be able to be mounted exactly the same but you could definitely get it to fit. Still stuck with hotter air and probably poorer performance or a wash if you're lucky. But the purpose is to attach it to the intake and route the filter pod into the fender. Which on our car it would not do. So in terms of the way it is engineered to work it doesn't fit our cars. So all those parts that serve to seal the filter and intake tube from hot air...you guessed it don't fit our car... Link to comment Share on other sites More sharing options...
Shadow_419 Posted December 29, 2017 Share Posted December 29, 2017 Sorry military mentality. Just because I'm not using something as intended doesn't mean I can't use it Definitely preaching to the choir though. It's more work than possible benefit in my opinion. If you want it for show, that's a different story. Link to comment Share on other sites More sharing options...
FLlegacy Posted December 29, 2017 Share Posted December 29, 2017 On a more positive note, the MAF is apparently the same between the 4th and 5th gen. Link to comment Share on other sites More sharing options...
DadMod Posted December 29, 2017 Author Share Posted December 29, 2017 I think that pretty much answers my question, appreciate the comments. So at this point, is there any point to doing anything to the intake other than a drop-in K&N filter? Link to comment Share on other sites More sharing options...
Sarang Posted December 29, 2017 Share Posted December 29, 2017 No. There is certainly no power benefit until you significantly upgrade the turbo. Remember also that any intake mod requires a pro tune for proper operation, and they won't necessarily work as well as stock even then. A downpipe will do more for turbo noises and response too. Link to comment Share on other sites More sharing options...
cww516 Posted December 29, 2017 Share Posted December 29, 2017 Also, I'd recommend an AEM filter over a K&N, if only because you don't have to oil it. Link to comment Share on other sites More sharing options...
GTEASER Posted December 29, 2017 Share Posted December 29, 2017 I think that pretty much answers my question, appreciate the comments. So at this point, is there any point to doing anything to the intake other than a drop-in K&N filter? Yes, a drop in AEM Dryflow filter. K&N is old tech. You can always get the Samco intake hoses to bling things up a little and smooth out the intake path between the MAF and turbo. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
DadMod Posted December 30, 2017 Author Share Posted December 30, 2017 Yes, a drop in AEM Dryflow filter. K&N is old tech. You can always get the Samco intake hoses to bling things up a little and smooth out the intake path between the MAF and turbo. Thanks, just made the change today. I've been feeling like old tech a lot lately too, but I'm working on it Link to comment Share on other sites More sharing options...
FLlegacy Posted December 30, 2017 Share Posted December 30, 2017 Try to stay away from suggestions from those who don't have a 5th gen legacy. Our cars are pretty unique and sometimes annoyingly so, lol. Other people who are uninformed will assume it has all the parts every other legacy/wrx has and their eyes will kind of gloss over when you try to tell them differently. Link to comment Share on other sites More sharing options...
GTEASER Posted December 31, 2017 Share Posted December 31, 2017 Try to stay away from suggestions from those who don't have a 5th gen legacy. Our cars are pretty unique and sometimes annoyingly so, lol. Other people who are uninformed will assume it has all the parts every other legacy/wrx has and their eyes will kind of gloss over when you try to tell them differently.That moment when you mention that it has a front low mount turbo and doesn't have an up-pipe.....lol! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
