scottmor31 Posted January 6, 2009 Share Posted January 6, 2009 I have an 08 Legacy spec. B. I want to go aftermarket with my clutch set-up, but have been unable to locate one specifically for it. Does anyone know what will work for this application? if anything yet? Thanks Scott Link to comment Share on other sites More sharing options...
fieldy72233 Posted January 6, 2009 Share Posted January 6, 2009 Dude, it is 10 threads down.... http://legacygt.com/forums/showthread.php?t=102993 Link to comment Share on other sites More sharing options...
scottmor31 Posted January 6, 2009 Author Share Posted January 6, 2009 Yeah but the stock part numbers for the 07 spec b and the 08 spec b are different according to my dealership. I just wanna make sure before I drop the money Link to comment Share on other sites More sharing options...
fieldy72233 Posted January 6, 2009 Share Posted January 6, 2009 Interesting. What does your dealership say? Link to comment Share on other sites More sharing options...
Rika Posted January 7, 2009 Share Posted January 7, 2009 the better question is why do you want a new one? Link to comment Share on other sites More sharing options...
fonts Posted January 7, 2009 Share Posted January 7, 2009 Yeah but the stock part numbers for the 07 spec b and the 08 spec b are different according to my dealership. I just wanna make sure before I drop the money I'm not aware of any differences between the setups for the 2 model years. Link to comment Share on other sites More sharing options...
scottmor31 Posted January 7, 2009 Author Share Posted January 7, 2009 I'll check again today Link to comment Share on other sites More sharing options...
scottmor31 Posted January 8, 2009 Author Share Posted January 8, 2009 the dealership says it should work Link to comment Share on other sites More sharing options...
Turninconcepts Posted January 12, 2009 Share Posted January 12, 2009 The clutch for the 07 and 08 sti have different parts numbers, but in the aftermarket they are the same. Tony Link to comment Share on other sites More sharing options...
fieldy72233 Posted January 15, 2009 Share Posted January 15, 2009 Hey guys, maybe you can provide a little more insight. The ACT contact on NASIOC just emailed me that they released a SPC B cluctch for the 07-09. Here is his justification for it? Can anyone let me know what this means? Are the 12 mm a difference? It seems the STi clutch would work fine but I don't know enough. Hey said, "The SB4 kits are for the STI and they have a 240 mm clutch, your car uses a 228 mm clutch. The only similarity is the release and pilot bearing between the two cars." Given its 200 dollars more, what are the implications? Link to comment Share on other sites More sharing options...
Guest Posted January 15, 2009 Share Posted January 15, 2009 Interesting news. You def. want sti clutch. Bigger disc is better. The only question is whether your stock fly will match to sti clutch. Link to comment Share on other sites More sharing options...
fieldy72233 Posted January 15, 2009 Share Posted January 15, 2009 Well, I was going to replace with the light weight fly wheel, I heard there were complications with that anyways. Sounds like if you don't want to replace the flywheel, this would the best option. Otherwise, go with the STi setup. Link to comment Share on other sites More sharing options...
