travgag Posted July 20, 2012 Share Posted July 20, 2012 Allrighty, so car is all back together and its been two nights trying to track down a spark, The car cranks but doesnt start, fuel pressure is good, everything is hooked up, i have 12 volts on the middle wire to the coil, im not sure if i have the right order for the injectors but it seams they only reach the one way, now initialy i couldnt make the wire for the cam sensor reach to be able to plug it in, after loosening the intake and wiggling it, i gained enough distance to plug it, i also thought i may have pinched the harness between the intake and the coolant crossover, but looking a photos thats were it goes, i have a Cel for cam sensor, P0340 i believe, and if i clear it, it comes back after i crank it over, so i pulled the intake off again, the real pain is the egr line !! and tested from the plug for the cam sensor to the main harness plug and had continuity, and no grounding out, i have a 2.2 95, so i took the can sensor out and plopped it in, no go still, and still cam CEL, Im not sure if you need a cam signal for spark, now that i say it i should of tryed on my 95 lol ! ive read about the module thats behind the breather, and checking timing again which i will do, now i removed the crank sensor by detroying it, thinking that would be an easy swap in and out, but not so much could another possibility be that i fried something because i cut a wire that was taped into the harness for the coil that was being used for a tack signal for the remote start, when i first tryed the car, three days ago i had forgotten it and it was dangling around and may have grounded out as i was turning it over, thanks for your time ! Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 20, 2012 I Donated Share Posted July 20, 2012 You need a cam signal to get spark. Check for pinched / broken wires and make sure all your grounds are hooked up. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted July 20, 2012 Share Posted July 20, 2012 Do you possible plug the sensors in backward? Cam to crank. Crank to cam Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
travgag Posted July 20, 2012 Author Share Posted July 20, 2012 dont think they reach, and the ground and there's also a signle wire sensor thats on the same wire, so doubt it, i did think about it tho Link to comment Share on other sites More sharing options...
meier motor sports Posted July 20, 2012 Share Posted July 20, 2012 betcha you got your cam sensor plugged into something else. what are your wire colors. do you have a similar plug plugged in some where else. iv done it on a pt cruiser after head gasket. not sure which but i had the cam plugged into the egr and egr plugged into cam or some shit. Link to comment Share on other sites More sharing options...
travgag Posted July 20, 2012 Author Share Posted July 20, 2012 yea, i know the cam sensor was a blue and yellow wire, and not sure but can the injector plug into the sensor ? Link to comment Share on other sites More sharing options...
99legacyturbo Posted July 21, 2012 Share Posted July 21, 2012 If you have a code for it it's most likely not plugged in or plugged in the wrong place or wires could have broken or worn and I'm pretty sure most plugs are shaped only for one thing each except I seam to remember the cam sensor plug being able to be mistaken for another plug just gotta remember what I'll check my harness tomorrow and get back to you Link to comment Share on other sites More sharing options...
JJay03 Posted July 21, 2012 Share Posted July 21, 2012 Those wires under the intake have to go in just the right spot to not rub. I rerouted mine a few times before I was happy with them placing the intake on while the engine was still on the stand. You must not have something plugged in correct. Did you label all the wires before you took them off? Sorry you are having issues I know how it feels to get all done and excited to fire it back up then have more problems. Hope you get it figured out soon. Oh I also destroyed my crank angle sensor removing it that bitch was corroded in there good. Wire brushed it good with the dremel after and got a delphi replacement from rockauto. Link to comment Share on other sites More sharing options...
travgag Posted July 25, 2012 Author Share Posted July 25, 2012 yea im going to have to remouve the intake and figure it out, and no i didnt mark all the wires, it seamed like i would be able to mistake them. thanks Link to comment Share on other sites More sharing options...
mnbd Posted July 25, 2012 Share Posted July 25, 2012 I'm fairly new to the game and am not sure how their cam sensors look, but if it's like a distributor, there could be the possibility of having it 180* off. Again, if I'm way out of the park just mosey on by this post. Good luck, keep us posted! Link to comment Share on other sites More sharing options...
joelwatts Posted July 25, 2012 Share Posted July 25, 2012 if you have a dvom, probe the crank sensor while cranking it over. you should see the voltage fluctuate between high and low. if its a needle type meter, the needle will sweep back and forth between set positions. that will tell you if the crank sensor is good. if it is, you can check the same wires at your pcm. if you don't have that signal there, it is in the harness. you can track down the break, or run new wires. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted July 26, 2012 Share Posted July 26, 2012 This is true bit you don't ever see a bad crank sensors. Never seen or heard of one going out. You just heed to test the wires at the ecu. The pinouts are at home if you want the numbers for the crank Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
travgag Posted July 29, 2012 Author Share Posted July 29, 2012 So i think il just run new set of wires from the cam sensor to the main harness, im thinking if i tugged on it to make up that 1/2 inch it might of broke internally, so swagon wagon would you be able to get the pinouts for me, so i can make sure im splicing the right ones, thanks ! Link to comment Share on other sites More sharing options...
travgag Posted July 29, 2012 Author Share Posted July 29, 2012 well im looking to see if i have the wrong plugs wired up, and behind the egr, with a small tube thats plugged into it, theres a plug thats orange and has a yellow with a red stripe and a smaller green wire the casing is orange, and the cam one I have now is blue and yellow, the casing is white, i looked on my older subi, 95 2.2 and its a white casing one on the front but both wires and blue and blue with white stripe and also on that small thing behind the egr, look like theres supposed to be two tubes but theres only one Link to comment Share on other sites More sharing options...
travgag Posted July 29, 2012 Author Share Posted July 29, 2012 Update/correction I looked into it, and on mitchell on demand it shows the wire being black and grey, i found a black and grey plugged into the injector and was able to swap them and now just to get a new crank sensor tomorrow and cross my fingers that she runs perfect ! i also found another little vacume line that was dangling on the erg. thanks guys Link to comment Share on other sites More sharing options...
