mhelouin Posted August 22, 2005 Share Posted August 22, 2005 Hello-- If one has already been put together, I apologize; I didn't see anything when I searched. I've seen some pix that people have posted of their installs, but I was hoping to get info on which wires to splice, how to access behind the dash, etc. so that I don't get in over my head on the install. Also, I'm curious if the gauge can be wired to dim when the headlights are turned on. Many thanks! --Marc Link to comment Share on other sites More sharing options...
Th3Franz Posted August 22, 2005 Share Posted August 22, 2005 Well I tapped off the vacuum line by the bypass valve, and the boost reading seems to be accurate. I then mounted the remote sensor upside down (make sure you do this) using a bolt near the brake master cylinder. I then ran the signal wire through the fender area and into the cabin. For tapping wires, I tapped the power wires to the little light in the cigarette lighter area. You can pull this part out. I still need to figure out why my gauge doesn't dim at all, but I don't mind it. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Nsaglibene Posted August 22, 2005 Share Posted August 22, 2005 I just have to ask my friend who helped me do it a few questions and than I will try to put together a walkthrough or somthing. Link to comment Share on other sites More sharing options...
jsalicru Posted August 22, 2005 Share Posted August 22, 2005 This applies to STi, but nevertheless... here's a How-To I made a little while back. http://homepage.mac.com/jsalicru/GaugesHowTo.html "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
mhelouin Posted August 22, 2005 Author Share Posted August 22, 2005 Thanks all for the information. Nsaglibene, I appreciate you talking with your friend espcially about how to mount in the LGT. Thanks again. --marc Link to comment Share on other sites More sharing options...
