Giovonage Posted June 18, 2013 Share Posted June 18, 2013 Once again my car is having issues... Every time I take a right turn (might be left also but in my neighborhood I can only take right turns) over about 10mph my car just dies. I've actually had this problem before and it had a simple fix; all I did was just scrub out the positive battery terminal and got rid of a ton of corrosion and problem solved. This time however is a different story. I recently disconnected my battery to clean my MAF sensor. Reconnected it, and the problem started. I tried to just do what I did the previous time but it didn't really work... Tried again and really tightened the cable down so it wouldn't lose connection... only helped a little bit; it still dies if I'm going faster than like 15mph It's really annoying and makes the car pretty much undrivable Link to comment Share on other sites More sharing options...
Max Capacity Posted June 18, 2013 Share Posted June 18, 2013 Have you cleaned the negative terminal too ? Have you made sure all the electrical connectors are tight and clean ? Most are fairly easy to take off and check. BTW, How old is the battery ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Giovonage Posted June 19, 2013 Author Share Posted June 19, 2013 Have you cleaned the negative terminal too ? Have you made sure all the electrical connectors are tight and clean ? Most are fairly easy to take off and check. BTW, How old is the battery ? Just cleaned the negative terminal, seems to have fixed the problem, which is strange because it didn't look like it had any corrosion or anything on it... Link to comment Share on other sites More sharing options...
Max Capacity Posted June 19, 2013 Share Posted June 19, 2013 I have learned to clean both terminals and then put a good coating of grease over, around and under them. it keeps out moisture. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
