Deadleave Posted July 20, 2010 Share Posted July 20, 2010 I know its summer, but.... I had a stupid idea, and just gauging how stupid it might be. So prevent the rings from rusting during winters, or when ever.... Anti-seize the rings, then saran wrap it all (just the section on the perch and rings) Good idea or bad idea ? Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 20, 2010 Share Posted July 20, 2010 It's double edged. Wrapping them will keep moisture IN as much as it keeps it out. Anti-seize might be OK on the rings. I just simply left my Endura-techs open to the winter (the harshest one we've had in MD in a LONG time), and didn't have any issues adjusting them in the spring. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Bolksey85 Posted July 20, 2010 Share Posted July 20, 2010 I think some WD40 every now and then would be fine. It's used to seal out moisture and the following corrosion quite often on other applications. Link to comment Share on other sites More sharing options...
m sprank Posted July 20, 2010 Share Posted July 20, 2010 WD-40 displaces water. That is what it does best. I like the WD idea. Link to comment Share on other sites More sharing options...
Bolksey85 Posted July 20, 2010 Share Posted July 20, 2010 WD-40 displaces water. That is what it does best. I like the WD idea. *Facepalm* on my part. That's what the WD even stands for! Link to comment Share on other sites More sharing options...
m sprank Posted July 20, 2010 Share Posted July 20, 2010 40th try they got the formula right, so the story goes... Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 20, 2010 Share Posted July 20, 2010 I would spray some sort of grease or greasy coating on them. It might be messy, but will stop corrosion, and can be power-washed off the following year. I wonder if PAM would work? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
m sprank Posted July 20, 2010 Share Posted July 20, 2010 Pam works great to keep mud from sticking. I used to use it on my fenders when the tracks were sticky. Grease would work, but dirt and debris get stuck in it. Even on a bearing too much grease is just as bad as too little. The real answer is remove them or perform weekly maintenance. I washed my car once a week all winter long in NY. Even when I had to heat the hose to keep the water from freezing. Be careful of the ice that forms from your wash water, gets slippery fast. LOL. But the underside of my car is B E A Utiful still. Link to comment Share on other sites More sharing options...
Bolksey85 Posted July 20, 2010 Share Posted July 20, 2010 Sprank, a tip for sticky tracks: Use a 50/50 solution of baby oil and water. It prevents rubber/debris/small children from sticking to painted surfaces while washing right off when you're ready. Link to comment Share on other sites More sharing options...
Th3Franz Posted July 20, 2010 Share Posted July 20, 2010 I use Rejex on my wheels and was really impressed. If I were to get coilovers, I would give this CorrosionX stuff a try. http://www.rejex.com/corrosionx.html -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Biggu Posted July 20, 2010 Share Posted July 20, 2010 when ever i get a set of new colovers i disassemble them down to the main components and then give them a nice layer of wax and every 2 weeks i will take off the wheels sprays them down to get salt off them and spray some silicone spray on them... works well for me. Link to comment Share on other sites More sharing options...
m sprank Posted July 20, 2010 Share Posted July 20, 2010 Sprank, a tip for sticky tracks: Use a 50/50 solution of baby oil and water. It prevents rubber/debris/small children from sticking to painted surfaces while washing right off when you're ready. :lol: That would work too. I guess everyone has their own "maintenance" routine. The key is to "maintain" rather than install and forget. Link to comment Share on other sites More sharing options...
Deadleave Posted July 21, 2010 Author Share Posted July 21, 2010 Okay WD 40 it is. Even on stock struts, drive around in bad NY snow for a day, and it gets caked everywhere. And cleaning it out is a mess, so Ill use the WD-40 to displace water, then wrap it loosely, not to seal but just to keep snow off the actual coilovers parts that need it. Ill check on it regularly and see how it holds up. Thanks guys Link to comment Share on other sites More sharing options...
Gmachine Posted July 21, 2010 Share Posted July 21, 2010 Before spinning the spring perch and lock ring into place.I wrap that part of the threaded shock body with a few layers of teflon tape. I also do this for the lower lock ring if the coilover has one. Link to comment Share on other sites More sharing options...
lil_z_33 Posted July 21, 2010 Share Posted July 21, 2010 i did silicon tape years ago on coilovers for my altima...unwrapped after winter and they were like brand new... Link to comment Share on other sites More sharing options...
