Clever Username Posted March 18, 2015 Share Posted March 18, 2015 I have an 05 GT wagon and I bought a set and I can't figure out where these fit. If someone has a pic of one install I would definitely appreciate it Link to comment Share on other sites More sharing options...
whitetiger Posted March 18, 2015 Share Posted March 18, 2015 they go on the lower front strut where it bots to the knuckle. they replace the OEM bolts there. Link to comment Share on other sites More sharing options...
Clever Username Posted March 18, 2015 Author Share Posted March 18, 2015 I appreciate the quick response. Just realized I didn't specify earlier but I meant for the rear suspension. Link to comment Share on other sites More sharing options...
whitetiger Posted March 18, 2015 Share Posted March 18, 2015 the rear suspension is a multilink, not a McPherson setup, so it does not use camber bolts. you can buy eccentric bushings for the upper control arm, but your bolts wont work back there. Link to comment Share on other sites More sharing options...
Clever Username Posted March 19, 2015 Author Share Posted March 19, 2015 Ah I see, thank you for the insight. Link to comment Share on other sites More sharing options...
hobo2701 Posted March 21, 2015 Share Posted March 21, 2015 arent there camber bolts that connect the rear lateral link to the subframe? Link to comment Share on other sites More sharing options...
