Throttlejockey Posted June 13, 2013 Share Posted June 13, 2013 Like the title says. Will The OEM sensors fit in my Rays G Games? Link to comment Share on other sites More sharing options...
.clipse Posted June 13, 2013 Share Posted June 13, 2013 TPMS sensors will fit in any wheel (sensor connected to the valve stems). the bitch part is having them re-calibrated Link to comment Share on other sites More sharing options...
Throttlejockey Posted June 15, 2013 Author Share Posted June 15, 2013 Why would they have to be recalibrated if they are from the same car? I thought the TPMS were part of the valve stem. I know the valve stems are different on the Rays. Link to comment Share on other sites More sharing options...
.clipse Posted June 15, 2013 Share Posted June 15, 2013 Why would they have to be recalibrated if they are from the same car? I thought the TPMS were part of the valve stem. I know the valve stems are different on the Rays. well you can have the valve stems with the TPMS sensors swapped over to the Rays. They are for the same car but you have to re-calibrate to incorporate the new tire sizes/psi. the TPMS sensors were calibrated for OEM spec wheels/tires. AFAIK Link to comment Share on other sites More sharing options...
