in1t Posted August 5, 2008 Share Posted August 5, 2008 hi guys, please check my fists logs, the car is stock MY05 LGT JDM (5mt). Engine also stock (only HKS SSQV installed). the main thing I'm concerned about now is high knock correction level (as you can see in logs). probably of crappy local fuel quality =\ hope you can tell me what's going on from my log and how can I rectify the situation. first run log, second run log + ecu rom ECO mode: log1, log2, log3 thanks!! Link to comment Share on other sites More sharing options...
Ridgeracer Posted August 5, 2008 Share Posted August 5, 2008 Whats your current IAM?? Seems like your car is in some sort of fail safe. Your running WG spring pressure...boost control is off. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
qikslvr Posted August 5, 2008 Share Posted August 5, 2008 The high POSITIVE Knock Correction is a GOOD thing. It's advancing the timing further and creating more power. Negative KC is bad. Let's kick this pig! Link to comment Share on other sites More sharing options...
qikslvr Posted August 5, 2008 Share Posted August 5, 2008 Whats your current IAM?? Seems like your car is in some sort of fail safe. Your running WG spring pressure...boost control is off. I noticed that too; Zero WGDC, so ya it's on spring pressure. Let's kick this pig! Link to comment Share on other sites More sharing options...
Infamous1 Posted August 5, 2008 Share Posted August 5, 2008 Whats your current IAM?? Seems like your car is in some sort of fail safe. Your running WG spring pressure...boost control is off. Strange enough if you look at his rom the wgdc initial A is actually 0% across the entire table. Also the max MRP is 9.67psi in table A as well. However the B tables are completely different and have expected targets. I am wondering how the JDM vehicles switch between tables, really makes no sense. However his log seems to be hitting all the values in the A tables fine. Link to comment Share on other sites More sharing options...
Ridgeracer Posted August 5, 2008 Share Posted August 5, 2008 Didn't get a chance to open the ROM earlier since I was at work..Interested to see how this pans out... "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
in1t Posted August 6, 2008 Author Share Posted August 6, 2008 here is my new log, please check. IAM is 0.93. What does WG spring pressure mean? Link to comment Share on other sites More sharing options...
Ridgeracer Posted August 6, 2008 Share Posted August 6, 2008 IAM should always be 1. Could be your gas. If this is a stock rom, then your gas is probably the main cause of your problem. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
in1t Posted August 6, 2008 Author Share Posted August 6, 2008 IAM should always be 1. Could be your gas. If this is a stock rom, then your gas is probably the main cause of your problem. is it possible to fix it? Link to comment Share on other sites More sharing options...
Ridgeracer Posted August 6, 2008 Share Posted August 6, 2008 Some torco would be nice. Not sure what octane boosters you have available to you though. WG spring pressure means that your car is using only the "turbo's wastegate spring to control boost". This is called mechanical boost control. The car is equipped with an electronic boost control system that allows the engine control unit to control boost with a solenoid controlling charge air to the WG actuator. Based on your logs, it seems that your WG spring opening pressure is .5 bar. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
in1t Posted August 6, 2008 Author Share Posted August 6, 2008 Ridgeracer Is there any way to change it to normal mode? maybe it happened because ECO mode was ON? Have no idea about USDM cars, but in JDM models there is ECO mode button on the driver panel. I forget to switch it off before log =\ Will log again w/o ECO mode Link to comment Share on other sites More sharing options...
Infamous1 Posted August 6, 2008 Share Posted August 6, 2008 Ridgeracer Is there any way to change it to normal mode? maybe it happened because ECO mode was ON? Have no idea about USDM cars, but in JDM models there is ECO mode button on the driver panel. I forget to switch it off before log = Will log again w/o ECO mode That sounds like your issue right there. If you review your rom you are running off the A tables for boost control (Target boost and Wastegate duty cycle). The B tables has your "normal" targets. Link to comment Share on other sites More sharing options...
caramall2 Posted August 7, 2008 Share Posted August 7, 2008 What's IAM again? Sorry, drawing a blank and search brought up nothing. Oops, never mind, I see it in the log (Ignition Advance Multiplier). Same thing as Dynamic Advance Multiplier (term Cobb uses)? Link to comment Share on other sites More sharing options...
in1t Posted August 7, 2008 Author Share Posted August 7, 2008 hey all, take a look at new logs w/o ECO mode (it's OFF now). Looks better first run log, second run log Link to comment Share on other sites More sharing options...
Infamous1 Posted August 7, 2008 Share Posted August 7, 2008 That looks better, funny you didn't notice that low boost before:p Kind of cool how you can switch to econ like that on the older models there. You might want to log feedback correction to insure you aren't knocking, the JDM rom's timing is all over the place. Link to comment Share on other sites More sharing options...
