DiegoM Posted October 19, 2013 Share Posted October 19, 2013 So I'm going to install am aftermarket deck in my legacy but I can't put the stock faceplate with the stereo so what do I do ? Where do I get an aftermarket faceplate ? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted October 19, 2013 Share Posted October 19, 2013 Why won't the stock face-plate fit? What weird-ass head unit are you installing? Link to comment Share on other sites More sharing options...
DiegoM Posted October 20, 2013 Author Share Posted October 20, 2013 It's a sony xpload head unit lol, same size as other head units .. Link to comment Share on other sites More sharing options...
Stevo F Posted October 20, 2013 Share Posted October 20, 2013 I just installed an aftermarket (single DIN) Kenwood deck in mine. It was practically a perfect fit, but I did need to widen out the hole in the trim piece for the radio faceplate as it was slightly wider than the OEM faceplate. Just took a few minutes with my Dremel tool. Actually the new deck really good in the Legacy since the faceplate is mostly all black like the original. Link to comment Share on other sites More sharing options...
Zues Marine Posted October 20, 2013 Share Posted October 20, 2013 does the faceplate actually fit the deck with them both out of the car? Link to comment Share on other sites More sharing options...
DiegoM Posted October 20, 2013 Author Share Posted October 20, 2013 The oem faceplate needs to be cut around the edges a bit if I want it to fit Link to comment Share on other sites More sharing options...
Stang70Fastback Posted October 20, 2013 Share Posted October 20, 2013 That's honestly going to be your best option. Grab a bit of Bondo and get to work! If you don't wanna mess anything up, go grab one out of a junkyard and use that one instead! Link to comment Share on other sites More sharing options...
Zues Marine Posted October 20, 2013 Share Posted October 20, 2013 bondo? why bondo? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted October 20, 2013 Share Posted October 20, 2013 In case once he cuts it up he wants to modify it to look better or something? Link to comment Share on other sites More sharing options...
stevenva Posted October 21, 2013 Share Posted October 21, 2013 Don't cut the dash trim. It's an ISO mount radio. The Sony radio trim won't be needed. I've seen so many people needlessly cut up a dash, only to rarely have it look OK. If you insist on using the Sony trim, try to modify the trim to fit the car, not the car to fit the trim. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
Stevo F Posted October 21, 2013 Share Posted October 21, 2013 I needed to cut the dash trim to put the new Kenwood in last weekend- its faceplate was clearly a bit wider than the OEM radio. I trimmed it with my Dremel tool and the Kenwood also had a piece of trim that snapped in place over the molding so you can't see where I cut it. I'm guessing the Kenwood has a standard size single DIN faceplate where the OEM Subaru radio might be a little bit smaller, but I could be wrong. Link to comment Share on other sites More sharing options...
stevenva Posted October 21, 2013 Share Posted October 21, 2013 The radio chassis sizes are the same. The faceplate trim is used when using the mounting sleeve instead of the side ISO mount screws in the factory brackets. As long as it came out good then that's what matters now. I doubt you'll be re-installing the factory deck ever RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
