Clod Posted March 13, 2011 Share Posted March 13, 2011 Has anybody had an issue with their power steering? My 07' steering wheel is begining to become difficult to turn. Any ideas? I checked the fluid level and the belt and they are both o.k. Hopefully it is not the pump or rack. Any idea if Subaru covers this under the power-train warranty? Link to comment Share on other sites More sharing options...
Icough Posted March 14, 2011 Share Posted March 14, 2011 I am having the same issue with mine but i have not gotten any answers Link to comment Share on other sites More sharing options...
Legacy51 Posted March 14, 2011 Share Posted March 14, 2011 What mileage ar you guys at? Anything similar? What symptoms were you experiencing prior to this? Also are there any lights on the dash? Link to comment Share on other sites More sharing options...
jagcars26 Posted March 14, 2011 Share Posted March 14, 2011 How's your front tire pressure ? low ? Link to comment Share on other sites More sharing options...
joedirtae09 Posted March 14, 2011 Share Posted March 14, 2011 maybe the power steering fluid needs to be changed? Link to comment Share on other sites More sharing options...
Soobydoo Posted March 14, 2011 Share Posted March 14, 2011 change the belt i had this same problem and it was the belt making it hard to turn Link to comment Share on other sites More sharing options...
Clod Posted March 15, 2011 Author Share Posted March 15, 2011 I only have 43,000 miles. The front tire pressure is good. Was your belt slipping? The belt looks fine on mine. Link to comment Share on other sites More sharing options...
Xterior Posted March 16, 2011 Share Posted March 16, 2011 Similar problem to mine, I changed the belt as well and no difference. Link to comment Share on other sites More sharing options...
Instanced Posted March 16, 2011 Share Posted March 16, 2011 Take it to the dealership. I had an issue with my power steering when I only had like 12k miles on it... heh the guy at the dealership asked if I ever checked the PS fluid because something was screwed up... I said no because I shouldn't have to check it with only 12k miles on it... they replaced whatever parts needed replacing for free. my issue was intermittent power steering... like it was on then turn a bit and it would cut out... then come back... very weird trying to drive it like that. if your under warranty still, go get it fixed for free. Link to comment Share on other sites More sharing options...
eze168 Posted June 7, 2011 Share Posted June 7, 2011 Clod, did you ever get your ps fix? I experience the same issue today, at low speed, i basically have no power steering (after getting my car back from a body shop, i had a rear end damage). I checked the ps fluid, it's at max and the belt looks fine also. Â Anyone know what the powertrain warranty is? I had my car since June 2007 with 30K on it.... Link to comment Share on other sites More sharing options...
PoisonousBeef Posted June 9, 2011 Share Posted June 9, 2011 Powertrain warranty is 5 years or 60k miles, but I've never heard of one covering power steering... Link to comment Share on other sites More sharing options...
MasAyinde Posted June 9, 2011 Share Posted June 9, 2011 I think this is caused by air bubbles in the system. It can be burped by taking the cap off, filling the power steering, then starting the car and turning the wheel from left to right about 4-5 times each. Make sure the fluid level stays topped off. Check for leaks in the system also. Link to comment Share on other sites More sharing options...
peteyjr Posted June 10, 2011 Share Posted June 10, 2011 Changed out my PS fluid a few weeks ago and bingo. Link to comment Share on other sites More sharing options...
eze168 Posted June 11, 2011 Share Posted June 11, 2011 Im going try to change out ps fluid then, im sitting at dealer now and they said theres no issue they can see... Link to comment Share on other sites More sharing options...
