Need some opinions...
I have and 2005 LGT 5EAT with 140k . What I wanted to ask everyone is what should I do. I have to replace all the Shocks, rotors, brakes, calibers and both Front Axles. With 140k on Motor and Trans it could go at any time. So should I place all of the items then rebuild whatever blows up or just buy a newer used car with lower Miles :confused:
O I'm a daily driver with a heavy foot. So most of the items will be upgrades.
What I did replace already
~Rallitek Sway-bars Front and back
~Swift sport lowering springs with Koni Shocks -- Over 60k miles ago making hell of a racket.
~Avo Lower arm bushing + 0.50
~Kartboy End links
You never stated that you have a problem, you just asked what to replace next.
So you have a noise that occurs when driving over a bump. I would check that the springs are correctly seated. In some cases the springs shall be seated in plastic retainers, and if they aren't then they will grind while they are working.
