Almatti Posted January 22, 2017 Share Posted January 22, 2017 On our 2015 Legacy 2.5i - purchased as CPO in May 2016 with 14K miles, which is my son's car seems to have something unusual. When you close the Driver's door, it doesn't close with the same solid sound of the other doors. it almost sounds more "tinnie" less solid? I have not checked it out at a dealer to check other cars at a dealer. I will shortly. Anyone else sense this? Link to comment Share on other sites More sharing options...
ehsnils Posted January 22, 2017 Share Posted January 22, 2017 Not that I have noticed, probably an adjustment issue. Unless there have been a bad repair of the door from an accident, look for traces of repairs, compare left and right side of car and if spot welds are visible in a different way. Link to comment Share on other sites More sharing options...
vtdog Posted January 22, 2017 Share Posted January 22, 2017 Probably when the body shop replaced the door after the wreck they used cheap parts Link to comment Share on other sites More sharing options...
08SpecB_DE Posted January 22, 2017 Share Posted January 22, 2017 Check all the nuts and bolts for the window motor and regulator. I would not be surprised if it's just cheap aftermarket parts but it doesn't hurt to rule out something being loose. Link to comment Share on other sites More sharing options...
Too40gawlf Posted January 22, 2017 Share Posted January 22, 2017 Lol. This cant be a serious post. If the door closes fine, dont worry about the 'softness' of the noise. Link to comment Share on other sites More sharing options...
andrew_l_s Posted January 23, 2017 Share Posted January 23, 2017 Poor man's dynamat works wonders for making doors feel solid. https://www.lowes.com/pd/Peel-Seal-Instant-Waterproof-Repairs-6-in-x-25-ft-Aluminum-Roll-Flashing/1018733 After a few hot days the tar smell is gone and haven't smelled it since. Lighting Mods: $10 Footwell Illumination | Tail as Turn | Fog as DRL Diode Dynamics C-Lights | RX350 Bi-Xenon Retrofit Link to comment Share on other sites More sharing options...
GTEASER Posted January 25, 2017 Share Posted January 25, 2017 Some 5th Gens from the factory had insufficient adhesive attaching the skin to the door frame and thus a tinny hollow sound. There was actually a TSB addressing it. Could be the same issue with some 6th Gens. Have your dealer check it out. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Milkywitness Posted January 25, 2017 Share Posted January 25, 2017 I actually might know exactly what you're talking about. A couple months ago I replaced all my speakers, so that means I had to take the panels off all the doors. When I put the panels back on and closed the door I noticed a tin/hollow sound when it would close. I have no idea if I only started noticing this sound because I was messing with the door, and it always has that sound or if I changed something on accident to give it that sound. GTEASER may be right, it would be good to have you go in and check it out! Then report back if they find anything so I can get it fixed too! :D Link to comment Share on other sites More sharing options...
Almatti Posted January 28, 2017 Author Share Posted January 28, 2017 There was no wreck of the car. It was purchased as a CPO. The Carfax was checked. I am going to have the sales dealer check it. Link to comment Share on other sites More sharing options...
Almatti Posted January 28, 2017 Author Share Posted January 28, 2017 GTeaser,do you have link to the TSB? Link to comment Share on other sites More sharing options...
Dark_Horse Posted February 2, 2017 Share Posted February 2, 2017 I have the same issue. Had dealer check it out said something was loose, they tightened it. but its back again just haven't tore door apart to look yet. very tinny sound Link to comment Share on other sites More sharing options...
Almatti Posted February 4, 2017 Author Share Posted February 4, 2017 Dark_Horse: Just he Driver's front door right? The others are more solid. Link to comment Share on other sites More sharing options...
Dark_Horse Posted February 4, 2017 Share Posted February 4, 2017 correct just my driver door. if it wasnt 17* i would tear door apart now but i dont have a garage. Link to comment Share on other sites More sharing options...
Almatti Posted February 26, 2017 Author Share Posted February 26, 2017 Update after a visit to the Dealer: Insulation in the door was Missing.... I told you something was wrong !!! Fixed - Good to go. The robots must have been Drunk that day ..... Link to comment Share on other sites More sharing options...
Brisvegas Posted February 26, 2017 Share Posted February 26, 2017 Update after a visit to the Dealer: Insulation in the door was Missing.... I told you something was wrong !!! Fixed - Good to go. The robots must have been Drunk that day ..... well done. You knew there was a problem and got it fixed. Link to comment Share on other sites More sharing options...
LatentWagen Posted February 26, 2017 Share Posted February 26, 2017 The robots must have been Drunk that day ..... Robots don't drink More likely an accident that never made it onto the CarFax. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
leolfds Posted February 26, 2017 Share Posted February 26, 2017 Had the same issue with the front passenger door. Dealer said it was the inner door bracket that was loose. Link to comment Share on other sites More sharing options...
lindjosh Posted April 7, 2017 Share Posted April 7, 2017 Interesting read. I recently picked up a used 2015 Legacy as well and noticed the driver driver door having an off sound when closed firmly. All of the other doors close and sound normally just as on my Forester or any other previous car. I may have to pull the panel to have a look inside. Link to comment Share on other sites More sharing options...
Almatti Posted April 8, 2017 Author Share Posted April 8, 2017 As indicated in earlier post, the drivers side door was missing the insulation. Go to the dealer to check it out. Not sure if there is a TSB about this, but it seems from posts here it has been experienced by a number of folks. Who knows, it may affect 2015 cars built on certain day or week. I was the one who detected this malady. Its my 30 year old sons car who said he really didnt notice it. Now he sees and hears the difference. Link to comment Share on other sites More sharing options...
lindjosh Posted April 9, 2017 Share Posted April 9, 2017 Do these doors typically have any deadner on the interior of the outer skin? I feel like other cars I've been inside the doors generally had at least one sometimes 2 pieces to cut down on outer skin vibration. Link to comment Share on other sites More sharing options...
andrew_l_s Posted April 10, 2017 Share Posted April 10, 2017 There's 1 piece on the outer skin, as well as rubber bushings between the skin and impact bars. I plastered the whole skin with peel n seal aka poor man's dynamat. Really works well for road noise reduction and giving the doors a nice solid thunk when closing. Lighting Mods: $10 Footwell Illumination | Tail as Turn | Fog as DRL Diode Dynamics C-Lights | RX350 Bi-Xenon Retrofit Link to comment Share on other sites More sharing options...
lindjosh Posted April 10, 2017 Share Posted April 10, 2017 I've got the bushings between the impact bar and outer skin but that's all, going to get something added in there asap. The hollow door sound kills me every time I close it. Link to comment Share on other sites More sharing options...
