Gex Posted May 31, 2012 Share Posted May 31, 2012 Hey Guys, I already ordered an invidia catless uppide and am now deciding which downpipe to go with. Not sure if I should go Catted or Catless (How much difference does it make? Beside being illegal emissions wise is there a big power difference?) I was also going to order a CBE (either invidia or magnaflow) but after reading on here I am worried that I might destroy the factory TMIC (dont really want to jbweld or modify the stock) and maybe want to replace that before I do the exhaust. Both cost about the same give or take. Car will be tuned at R&H garage in Seattle if that make any difference. Also is there any other parts I should consider? I am running the stock turbo and do not plan to change. Looking to get a 20-30hp gain. Thanks for your help. Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted May 31, 2012 I Donated Too Share Posted May 31, 2012 biggest difference is price between catted/catless. if you go stage 2, you'll most likely have to deal with the IC issue. Sounds like for your needs, a good stage 1 protune will do the trick. Link to comment Share on other sites More sharing options...
Dujo Posted May 31, 2012 Share Posted May 31, 2012 You will lose some power using a catted vs a catless. However, a catted aftermarket downpipe will still be a significant upgrade over stock. A catted aftermarket will likely have some sort of high-flow cat that will get you almost as much as a catless downpipe. Catted is much more expensive though because the cat contains precious metals. Link to comment Share on other sites More sharing options...
Gex Posted May 31, 2012 Author Share Posted May 31, 2012 Yeah I have been debating on whether I could get the car past emission or not. It wont throw a CEL due to the tune so it should be fine catless. Will I get a gas smell being catless? I think ill save a bit more money and buy the process west TMIC and magnaflow. Then throw them all on at the same time. End of June/Early July car should have the TMIC,Catless DP and UP,CBE, and pro tune. Bet it'll be a whole different beast! I already had a comp stage 2 clutch,flywheel, and snout kit installed so I should be good for the drive train (fingers crossed). Maybe have them throw on one of the beefier tranny mounts. Really just looking for dependability. The car is not a DD but will see plenty of miles. Link to comment Share on other sites More sharing options...
Dujo Posted May 31, 2012 Share Posted May 31, 2012 Stage 2 stuff should be pretty reliable. I've got a used 08 OEM LGT uppipe, used Cobb catted, bnib Borla catback, and a bnib Process West intahcoolah all to go on at the same time. So I've got pretty much the same thing going on that you do. Maybe a little more conservative with the catted dp and the 2.5 inch catback. There is a different smell coming out of the catless cars vs catted. How much it bothers you and how much you notice it is a bit of a personal preference sort of thing. Personally, I can't smell the difference, but I have a horrendous sense of smell due to heavy allergies. Fyi ... the PW intahcoolah is expensive. Obviously, I thought it was worth it though. Link to comment Share on other sites More sharing options...
brad_houck Posted June 1, 2012 Share Posted June 1, 2012 if youre only looking for a 20-30hp gain i would try out an opensource stg1 tune. also i have a catless dp and only get the fumes once in a while and im used to them by now so i dont even realize it. if you wanna save a ton of money, drop the aftermarket intercooler and just bulletproof the stock one some how. Link to comment Share on other sites More sharing options...
