carlson Posted August 6, 2011 Share Posted August 6, 2011 Well I should of known better but i wanted to go to the track to see what she was capable of. On my second pass I launched the car and went to shift into second gear and when I did so it wouldnt go into gear and felt like something was holding it back. Got to the end of the strip and tried to put it into any gear and nothing. But when i try and put it into reverse it grinds just like if you dont come to a complete stop before putting it into reverse when backing up. What are your guys thoughts? Im going to get it towed to my work today and see if i can find anything wrong with it. Link to comment Share on other sites More sharing options...
Balrock Posted August 6, 2011 Share Posted August 6, 2011 What did you get in your first pass? What mods? Oh, sounds like your transmission is in trouble. Look for a used one on here or junk yard. I got my used one with 8,000 miles for a grand. GL and sorry. Link to comment Share on other sites More sharing options...
carlson Posted August 6, 2011 Author Share Posted August 6, 2011 first pass was terrible, 15.4 with a 2.6 sixty........ I have invidia exhaust from the header back, avo intake, and a custom tune. Im hoping for a broken shift cable but who knows at this point everyone thinks something different. Link to comment Share on other sites More sharing options...
ehsnils Posted August 6, 2011 Share Posted August 6, 2011 Blown clutch is the cheapest possibility since it's a wear item. Just for the stupid sake of it - check that the clutch arm moves when the pedal is pressed - so you aren't having a leak in the hydraulics or did get some air into it. And also try to shift around the gears with engine off, if you can get into the gears then it may just be that the sync rings was blocking you from second gear. You may have to try some odd patterns to make sure. Next step is to lift the engine out of the car or drop the gearbox (whatever you like the most), but dropping the gearbox may be best if it needs to get replaced. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2011 Share Posted August 6, 2011 Shift cable ? Is this a manual or automatic ? What year Legacy ? If it's tranny, pull it instead of the engine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
carlson Posted August 6, 2011 Author Share Posted August 6, 2011 Its a manual tranny and a 2005. im just trying to find a tow truck driver that will move my car for cheap instead of a heavy bill. Then ill get a chance to look at it Link to comment Share on other sites More sharing options...
TRSCobra Posted August 6, 2011 Share Posted August 6, 2011 It's definitely not a shift cable. These cars use rod linkages for the shifter. Does your clutch pedal feel the same as before? Link to comment Share on other sites More sharing options...
Balrock Posted August 6, 2011 Share Posted August 6, 2011 Be sure you get a flatbed, but I am sure you know that. Link to comment Share on other sites More sharing options...
carlson Posted August 6, 2011 Author Share Posted August 6, 2011 TRS - Ya im pretty sure it feels the same but to be honest i couldnt say for sure i was to pissed off last night Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2011 Share Posted August 6, 2011 I guess its to late now, but a AAA membership with 100 miles towing has saved us a couple of times. The house is 95 miles from Lebanon Valley Dragway. They brought the Civic home twice before we got a trailer. Where do you live ? Sounds like it could be something in the tranny. Have you ever removed one of these before ? Check out some of the threads in the transmission forum or DIY forums. There was one there the other day about different ways to get the axles out of the tranny. Something about disconnecting the LCA and swing it out of the way. Me, I just pull the axle like I was replacing the axle. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ehsnils Posted August 6, 2011 Share Posted August 6, 2011 Rent a car trailer at U-Haul and load the car on that. http://www.uhaul.com/Reservations/EquipmentDetail.aspx?model=AT Of course - you need a car to tow the trailer with, but I hope that you have a friend with a trailer-friendly vehicle. Link to comment Share on other sites More sharing options...
ehsnils Posted August 6, 2011 Share Posted August 6, 2011 B.t.w. make sure that you get a trailer with a winch or that you have a good winch to load the car on the trailer with. Electrical winches are good to some extent, but a muscle operated one allows for better control. Link to comment Share on other sites More sharing options...
carlson Posted August 6, 2011 Author Share Posted August 6, 2011 well I got it back to my shop and after cooling down a bit I hopped in it and when the car is off I can put it into every gear but when its on I cant. Im leaning towards the clutch Link to comment Share on other sites More sharing options...
ehsnils Posted August 7, 2011 Share Posted August 7, 2011 And does the clutch arm move when you press the clutch? Another thing I know is that the throwout bearing on some clutches are of "pull" type and is just held in place with some locking mechanism that "clicks" it into the spring fingers. I suppose that if you have that kind of clutch it may even be that the throwout bearing has disconnected itself from the clutch, in which case the clutch will stay engaged regardless of how much you press the pedal. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 7, 2011 Share Posted August 7, 2011 On that thought, make sure the piston on the slave cylinder is moving in a horizontal plain. If the clutch fork fell off the pivot ball the piston will be moving in the downward plain. You may be able to pull the fork back up and pop it back on the ball. On the winch idea, my Superwinch 5000 on the 18ft open trailer works well. It came with a 30ft remote control. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
frank_ster Posted August 7, 2011 Share Posted August 7, 2011 engine off.. put in first gear. push down clutch pedal, crank engine, CAR WILL PROBABBLY START MOVING drive home or to shop not using the clutch. ie trucker style. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ehsnils Posted August 7, 2011 Share Posted August 7, 2011 engine off.. put in first gear. push down clutch pedal, crank engine, CAR WILL PROBABBLY START MOVING drive home or to shop not using the clutch. ie trucker style. - I have done that - cable broke on a cable operated clutch I had on my '82 subie. Link to comment Share on other sites More sharing options...
