garygbnj Posted August 29, 2014 Share Posted August 29, 2014 176k-New throttle body 1 yr ago. The throttle body replacement stopped the intermittent stalliing for a while. Started again after about 8 months. Typically occurs (intermittent) after a long (5-8 minutes) at a more or less continuous speed. As I come to a stop the engine stalls. Starts immediately. Have tried cleaner in the tank (no effect), reset the idle (cold engine, disconnect battery, reconnect and allow to idle to normal operating temp). My mechanic is at a loss as to what to do. Any suggestions? Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted August 29, 2014 Share Posted August 29, 2014 I'm guessing you have never replaced the black o-rings between the intake manifold and the TGV's. When you see the new larger orange one's you'll understand the issue. I see your other threads, are you located close to www.AZPinstalls.com ? Mike has a real shop in NJ may be have him check it out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted August 29, 2014 Share Posted August 29, 2014 vacuum test and watch the needle jump around.. Then plan on compression and leakdown tests.. theres been quite a few threads about this.. Throttle body worked for me for about a year, it actually stalled this morning at a Dunkin Drive Through.. some people have resolved it by cleaning or replacing OCV's.. Im assuming you cleaned the MAF before you reset the idle? Link to comment Share on other sites More sharing options...
Brian3676 Posted August 29, 2014 Share Posted August 29, 2014 Do u have a light weight flywheel? My lgt did this with the light weight flywheel. Exactly as you describe. Got rid of it for a stock SMFW, has not happened one time since Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted August 29, 2014 Share Posted August 29, 2014 Just for shits and giggles through on the forge BPV I had for when the build gets done, reset ecu and its running mint now.. Not sure if its just clearing the ecu but we will see. Link to comment Share on other sites More sharing options...
