relative4 Posted March 5, 2016 Share Posted March 5, 2016 Doing my timing belt next month, and in the past I've held the crank pulley with a chain wrench, which sucks. This time I want to use a better method. I'm considering the old belt-around-the-alternator trick, the Subaru OEM wrench, and the Company 23 tool. What are people's takes on these? Can the alternator be damaged with that approach? Does anyone find one of the tools to be better than the other? Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 6, 2016 Share Posted March 6, 2016 Grimmspeed crank pulley tool Link to comment Share on other sites More sharing options...
biggreen96 Posted March 6, 2016 Share Posted March 6, 2016 Did my Tbelt today. Used the starter bump method to loosen the bolt. Prybar/big screwdriver in the flywheel teeth from underneath to get it back on. One arm holding the prybar, one torqueing the crank pulley bolt. Link to comment Share on other sites More sharing options...
KRM Posted March 6, 2016 Share Posted March 6, 2016 If I'm in the spot where the starter isn't available to bump over the motor for the quick way of removing the pully. Using two short ratchet extentions placed in two of the 4 holes on it and a breaker bar for leverage works well. Link to comment Share on other sites More sharing options...
WahooNo2 Posted March 9, 2016 Share Posted March 9, 2016 depending how much time you want to spend and what tools you have available you could make one i made mine with a 3 foot bar of steel, nuts, washers, and bolts/alltread, electrical box covers, hack saw, file, and drill Link to comment Share on other sites More sharing options...
