Kreamer67 Posted March 12, 2011 Share Posted March 12, 2011 So today i decided on a whim to remove the carpet in the back drivers seat area of my 06 LGT to attempt to troubleshoot the powerseat issue ive been having(they dont work). low and behold i stick my hand under the carpet to find POOLS of water buildnig up. which would account for why my TPMS harness is shorting out (i know remove it) and why my seats probabloy dont work. ive ready on many places that the AC drain line gets backed up. but seeing as the ac hasnt beeen run in months, im really doubting this,. this appeared to be dirty water probably taken on from snow. im also hearing about a drain plug on the floor pan. has anyone else had a problem with this or do you know where the plug is? Link to comment Share on other sites More sharing options...
Madjik_Man Posted March 13, 2011 Share Posted March 13, 2011 When my AC drain line was plugged and leaking the passenger front foot well is what was soaked. Link to comment Share on other sites More sharing options...
Kreamer67 Posted March 13, 2011 Author Share Posted March 13, 2011 yeah everything ont he drivers side is soaked. badly. Link to comment Share on other sites More sharing options...
B-Power-B Posted March 14, 2011 Share Posted March 14, 2011 Do you have a sunroof? Link to comment Share on other sites More sharing options...
Kreamer67 Posted March 15, 2011 Author Share Posted March 15, 2011 yes i do that was my other guess Link to comment Share on other sites More sharing options...
Kreamer67 Posted May 1, 2011 Author Share Posted May 1, 2011 UPDATE. upon tearing into the car some more i found the source of most of my electrical problems and my water leakage problem. open the drivers side door. look along the pillar for a hole punched into it. this runs down the pillar on the inside, i my self removed the grommet foolishly and ran 4awg wire through it for my audio system, after i pulled back my carpet i poured water down the pillar and saw a small amount of water on the floor. currently i have a half ass fix of a small strip of duct tape over it to deflect the water until i can remove the fender and silicone around it. hope this helps with everyone elses problems Link to comment Share on other sites More sharing options...
Kreamer67 Posted June 1, 2011 Author Share Posted June 1, 2011 UPDATE: the g-fix (duct tape) seems to be working...im confident now that this is the problem also could be causing many peoples spedometers to stop functioning. Link to comment Share on other sites More sharing options...
