07spec Posted May 9, 2011 Share Posted May 9, 2011 Maybe we had another thread about this and I missed it? Anyway, I know it sounds silly, but my trunk release has starting acting up. I pull the lever on the floor repeatedly to open the truck, walk back there to open it, and it’s still locked. It's an 07 SpecB. The only way I can open my truck is by pushing the button on the remote fob, WHILE physically pulling the truck up. Only way. Almost like the connection from the lever on the driver’s side floor to the actual trunk release is broken? Anyone have an idea? Thanks... Link to comment Share on other sites More sharing options...
ShadowImg Posted May 9, 2011 Share Posted May 9, 2011 Are you sure it's locked or just stuck? The seal on mine is always really sticky, and even when I pull the release, it doesn't open, I have to grab it and pull up with a decent amount of force to get it to go. Link to comment Share on other sites More sharing options...
07spec Posted May 9, 2011 Author Share Posted May 9, 2011 Good point, it may just be stuck. Link to comment Share on other sites More sharing options...
ShadowImg Posted May 9, 2011 Share Posted May 9, 2011 I always attributed it to heat + black car, it seems like the weather seal around the trunk actually melts to some extent and nearly glues the thing shut. Good for keeping water out I guess, but it does take some effort to get it open. Link to comment Share on other sites More sharing options...
DocHolladay23 Posted May 9, 2011 Share Posted May 9, 2011 Mine also does the same thing, I attributed it to the springs (mine are missing the clip in the middle so I didn't know if that was why or not) Look at your dash when you pull the release lever and see if the trunk lights up then goes out right away, that way at least you know the release is working! [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
07spec Posted May 9, 2011 Author Share Posted May 9, 2011 Another good point! I did look at the dash, and the trunk does light up right away. So the release is working. I think it might just be sticking. Link to comment Share on other sites More sharing options...
Lardo420 Posted May 16, 2011 Share Posted May 16, 2011 http://legacygt.com/forums/showthread.php/trunk-release-works-poorly-156788.html?t=156788 Dealer should replace the cable for free, plus you will most likely get a 2011 Leggy with 600 miles on it like I did for the day Link to comment Share on other sites More sharing options...
dr_sharp Posted May 23, 2011 Share Posted May 23, 2011 Sometimes when i pull the lever it will "stick" and remain "up" after I've pulled it. I have to push the lever back down to the floor. It does open the trunk, but the cable is clearly snagging on something. lol Link to comment Share on other sites More sharing options...
Xyklok Posted August 14, 2014 Share Posted August 14, 2014 Sometimes when i pull the lever it will "stick" and remain "up" after I've pulled it. I have to push the lever back down to the floor. It does open the trunk, but the cable is clearly snagging on something. Bumping a 3 years old thread I've got the same problem then described above. Anyone have any clue what the problem could be? Couldn't find anyone else with this problem after searching. Link to comment Share on other sites More sharing options...
spc2125 Posted September 18, 2014 Share Posted September 18, 2014 bump again. I have this problem but i noticed the cable to the trunk release lever is gone. Any ideas? Link to comment Share on other sites More sharing options...
