Jdubgt530 Posted July 19, 2015 Share Posted July 19, 2015 So I did my head gaskets on my car with the engine in. And the tail end of it but my engine won't go back into to place. It drops onto the cross member about .5" off of the mount holes any ideas what I can do? Link to comment Share on other sites More sharing options...
johnegg Posted July 19, 2015 Share Posted July 19, 2015 did you remove the ''dog bone'' trans mount at the top center on the fire wall? that makes a huge difference. Link to comment Share on other sites More sharing options...
Jdubgt530 Posted July 21, 2015 Author Share Posted July 21, 2015 I took out the dog bone still have problems. I talked to my buddies mechanic and he said to lift it from the trannypan to lift it up level and it will drop right in Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 21, 2015 Share Posted July 21, 2015 Lube up the mounting pins with grease and that will help. An engine leveler attachment for the cherry picker allows you to tilt the engine which also helps. Jacking up the trans is a good technique as long as you are careful where you mount the jack. Link to comment Share on other sites More sharing options...
Jdubgt530 Posted July 22, 2015 Author Share Posted July 22, 2015 My buddies mechanic said that just from the tranny pan will do the trick with a wood block onto of the jack. Just need to bring it up level because my current problem is that since I did my head gaskets and head replacement in the engine bay I jacked the engine up making the engine tilt up as I jacked it up from the oil pan. So this better work since I will be lifting it level not at a tilt. Link to comment Share on other sites More sharing options...
