N.Y.X. Build: Sold the LGT on to the '08 OBXT Stage 3 Build
N.Y.X.
Username: N.Y.X.
Year: 2008
Make: Subaru
Model: Outback XT
Trim: Limited
Color: Newport Blue Pearl
Miles: 89K miles as of 4/2015
Purchased: 4/2015
:bbq:Mods:bbq:
Engine/Performance:
Perrin Catted Downpipe w/ Tig Welded Wideband Bung
Perrin EL (fixed by Perrin) Headers
Fast Motorsports Retrofitted LGT Catback
Grimmspeed Uppipe
Grimmspeed Catback adapter
Grimmspeed Gaskets
Grimmspeed EBCS
JMP 9 Blade Billet Ball Bearing 16G Turbo
Custom Stainless Braided Turbo Oil Feed/AVCS Lines
Grimmspeed TMIC
KSTech Air Intake w/ Heat Shield (not installed)
ID1000CC Injectors
DW65C
Forge Motorsports BPV
Killer b Oil Pickup and Baffe
Mishimoto Turbo Inlet (Red)
Perrin Pitch Stop Mount (Red)
Cryotune Performance Dyno Tune 91 Oct.
Brakes/Suspension
04 STI Brembo F/R Calipers
04 STI Brembo F/R Rotors
KNS STI Conversion E-Brake Shoes
KNS Rear Brembo Brackets
Stoptech F/R SS Brake Lines
Yokohama YK580 235/40/R18
Rota Gravel 18x8.5
BCBR LGT Height Coilovers
Whiteline Rear Control Arm Bushing KCA399
Whiteline Roll Center Steer Kit KCA313
Whiteline Front LCA Inner Bushing Set W53353
Whiteline Front Sway Bar BSF30Z
Whiteline Rear Sway Bar BSR39Z
Beatrush Rear Strut Bar
OEM LGT Lateral Link Assemblies
2-OEM LGT Rear Control Arms
Moog Front and Rear Sway Links
Interior:
Kartboy STS w/ Bushings
TWM Performance Weighted Knob
Redline Goods Shift/Ebrake Boots and Armrest Cover
USDM STI Pedal Set
USDM 4th Gen STI Steering Wheel/Airbag
Weathertech Black Floor Mats
OEM Rear Cargo Mat
Rear Cargo Awning, Net and Tailgate Finisher
Exterior:
Custom Grille
Custom Halo Headlights
Halo Fog Lights
Grimmspeed Red Alternator Cover
JDM BP5 Face Lift Taillights
JDM Facelift Rear Gate Garnish w/ LED Fog Light (Not Installed)
Redline Goods Hood Strut Kit
20% Window Tint
Yellow Fog Light Tint
Electrical/Lighting:
Sunpro Electrical Oil Temp & Boost Gauges
AEM A/F Gauge
Mishimoto Sandwhich Adapter
Custom 2 Gauge Cubby Pod (A/F & Oil Temp)
Universal Swivel Gauge Mount (Boost)
Morimoto H7, 35W, 5500K HID's w/ Anti Flicker Resistor
Optima Red Top Battery
Maintenance:
Subaru Blue Oil Filters
Schaeffer's 9000 5W40
Motul 300 Gear 75W90 Rear Diff @ 90k
Schaeffer's SCH-293 75W90 Front Diff @ 90k
OEM Oil Cooler Seal @ 90k
Gates Timing kit w/ Subaru OEM Waterpump/Gasket/Thermostat @ 92k
Gates AC and Serpentine Belt @ 92k
2-New OCV's Part #: 10921AA080 @ 92k
Southbend Stage 3 Daily Clutch, OEM Flywheel, Bearing, Fork, Boot, Clips @ 96k
2-New Front CV Shafts @ 92k
4-NGK Iridium LFR7AIX @ 96k
Stoptech F/R Brake Pads @ 94k
http://i1063.photobucket.com/albums/t503/childreth13/10995556_10100427159196506_3541582807534182593_n_zpsco72gouz.jpg
http://i1063.photobucket.com/albums/t503/childreth13/14650081_10100729207349586_7065696213256640909_n_zpskmbgwtbt.jpg
OBXT Build starts on post #125
http://legacygt.com/forums/showthread.php/n-y-x-build-sold-lgt-08-obxt-stage-3-212787p4.html
  • Replies 340
  • Created
  • Last Reply
Gotcha, that came from the place I got it from. I will change it out next time around!!
SOLD 4/2015
Year: 2006
Make: Subaru
Model: Legacy GT
Trim: Limited
Color: Obsidian Black Pearl
Miles: 80K miles as of 8/15/13
Purchased: 7/2/13
Mods
Engine/Performance:
Stage 2 Cryotuned on 91oct
SPT Intake
Perin Uppipe
Grimmspeed Gaskets
Custom CBE (Going to add 2 universal skunk2 mufflers and custom mid and y pipe)
CUSCO Front Strut Tower Bar
Cobb STS
STI Boost Pill
Brakes/Suspension
Front Centric Premium Rotors @ 83k
Rear Centric Premium Rotors @ 83k
Stoptech Street Pads F/R @ 83k
Yokohama YK580 215/45/R17
Rota Gravel 18x8.5 (Summer Set)
Interior:
All Weather Floor Mats
Exterior:
Window Tint
Black DEPO Headlights
Plastidipped Grill
Plastidipped Rims
Thule 480XT Roof Rack
6000K HID Headlights
Maintenance:
IP&T Oil Line
Puralator One Oil Filter
Rotella T6 5w40
Autocraft Gold Battery @ 80k
NGK SILFRA6A @ 81k
Motul 300 Gear 75W90 Rear Diff @ 81k
Red Line Lightweight Shockproof/Motul 300 Cocktail @ 81k
Timing Belt Replaced with Gates Kit, Subaru waterpump, gasket, thermostat @ 83k
Both Front hubs Replaced w/ Moog 513220 @ 87k
Stage 3 Collection:
Grimmspeed EBCS (acquired, not installed)
BNR 16G (acquired, not installed)
Grimmspeed TMIC (acquired)
DW850CC Injectors (not acquired)
DW65C (acquired)
Perrin Turbo Inlet (not acquired)
Turkeylord Blue Tee replacement (not acquired)
Boost, Oil Temp Gauges (not acquired)
2-New OCV's (not acquired)
Stage 3 Cryotune 91oct (once I acquire then install everything I will limp over to Dave's for a stage 3 tune)
Photos:
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130707_104533_672_zpsb1f47de7.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_164922_647_zps5c0903c4.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_165007_092_zpscdbf56e0.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_164938_917_zpsbd076e19.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_164948_771_zpsadcd7df0.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_164914_752_zpsa5878156.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_165116_117_zps0b312e7a.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_165103_969_zpsddc3fa19.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_165606_369_zps67a0341d.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130819_185140_030_zpsc5cd0fa7.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130808_142616_875_zps50e28305.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130812_202023_483_zpsf032d97e.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130808_175139_384_zps8c6e0a5e.jpg
Based off this statement, do a lot of people run 5W50? I see a lot of posts where people run 0W40...
5W30 is pretty thin when hot.
Too find out what's best for our (EU) turbocharged Subaru engines, here in Holland we had an engineer of Kendall Oil taken oil samples from 150+ car's.
(This fellow also works on the best oil for top-fuel dragsters)
The samples where taken to the Kendall labaratories for analysis, and checked on everything you can imagine. So traces of metals from all engineparts, but also dilution with gas, sand, etc.
According to the engineer turbocharged performance engines like our's should not use rather thin oil, cause the engine's produce pretty high torque at relatively low rpm's. An other item is, they can also run relatively high top rpm's.
These fact's plus outcome of the oilreport, the conclusion was:
All 0W.. and ..W30 samples contained more metal parts than average.
The range 5W40, 10W40, and 5W50 came out best, with 5W50 as the absolute winner.
According to this engineer, most car manufacturers prescribe thinner oils, cause of the cold start. In practice most people do not take the time for the engine oil to reach working temperature. Premature wear out could be an item then.
5W50 provides a healthy cold start, and a good lubrification on high temperatures.
And this little gem was underneath... http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1293170&page=all
The mod bug bites again...i had my car stock for 3 1/2 years and collected parts from msprank group buys, etc...and so glad that i started to mod...it sure is a fun car! Had to install my parts this spring cuz next year is the big wedding...but i am saving for a turbo upgrade and supporting mods...
Enjoy the car and let the modding begin!
Ive been running shell rotella T6 for the last year and its good stuff...if it werent for these forums..i wouldve just used conventional 5w 30
Are you installing parts yourself? I hosted install days in my garage =)
Follow me on IG @chefodiycarguy
and @chefo.soriano
I've been building my Xterra for the last 3 years and it just became too much for a daily driver. So that's why I picked up the subie. I plan on installing all the parts myself as I do all the work on my vehicles and in the chance I can't do it, odds are one of my local buddies can. I also host local mod days, trail runs, shooting/camping weekends, etc. I like to get together with other mod enthusiasts!
Here's my trail rig, I'm actually installing an ARB locker as we speak!!
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130720_140326_750_zps413f65ed.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130821_210659_020_zpsaf688857.jpg
  • 2 weeks later...
Wanting to change out my fluids in both diffs and the 5MT but seem to be getting mixed signals. I would like to swap all the fluids (including the oil w/ T6) and change the spark plugs before I go for my tune...
What do some of you local guys prefer?
  • I Donated
put OEM plugs in when you swap those. Otherwise looks good, and swap the cusco front strut tower bar from "performance" to "ballast adding". Because of the front strut tower setup in these cars that does literally nothing for your performance except add weight to the front end. The front tower strut mounts are welded to the firewall and are braced by that already.
  • I Donated
I didn't notice a difference. done it twice now with the redline, Once when I first got the car (99,000 miles) because I didn't know when it was last done and once a couple months ago (132,000 miles). I went with it because that's what was in the pictoral method to changing the fluids that you posted in the other day. I might try the cocktail next time just for chits and giggles.
Sooooo ended up by going with BAC5.2's cocktail; returned the valvoline and ordered up 3 qts of Red Line Lightweight Shockproof and 2 qts of Motul 300 Gear 75W90. Figured I would order another and do the rear diff at the same time! $90 with free Prime 2-day shipping from amazon, not too bad!
I will post an update with my results:)
So ordered up the Red-Line Lightweight Shookproof, few qts of motul 300 gear (for MT cocktail and rear diff) through Amazon. Got a couple puralator one filters, 4 replacement spark plugs, and a smoked plate cover for the rear from advanced auto with a $50 off $125 promo code picked up in store (ignore the royal purple, that's for my xterra). Just have to swing by walmart after work and pick up a couple gallons of Rotella T6! I'll be a happy camper!!
http://i1063.photobucket.com/albums/t503/childreth13/Untitled_zps2b7c955c.jpg
I can't wait! But still putting together some of the final pieces of the puzzle. Fluids and all the pre-tune/scheduled maintenance will be done by the end of this week. But I still need my grimmspeed headers gasket to arrive and my "fixed" EL headers! Oh and the custom y-pipe to be welded up. Then it will be time to get road tuned!
Drained and filled the 5MT with the Shockproof and Motul 300 cocktail; noticeably smoother in every gear and feels like new. Took the crunch out of 4th all together. Thanks for the help everyone!
How some of my oil arrived:/
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130909_170828_195_zps75460fec.jpg
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130909_191258_904_zpsbf233090.jpg
Panning for gold;)
http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130909_184326_368_zpsebd84b46.jpg
