westy66 Posted May 13, 2013 Share Posted May 13, 2013 i have a LOUD exhaust leak that sounds like a pissed off rattle snake. only hear it under boost. (its not knock) ive just finished checking all the bolts on the header, UP and turbo. what else could it be?? i havnt had anything apart recently. could the wastegate make that much noise? how can i check? i have a Perrin IC, i dont think that O-ring could just start leaking could it? i have a Prodrive UP with the flex joint. it looks in good shape, but maybe something inside the joint is rotted and leaking?? need some ideas Link to comment Share on other sites More sharing options...
