Rester5350 Posted November 19, 2012 Share Posted November 19, 2012 I know this is a fairly common swap but i have not been able to find the answer to these questions. I do have a set of mostly complete lgt rear knuckles. ( they are pretty rusty ) 1. Will my OB parking brake work with the lgt rear rotors ? 2. Are the lgt rear knuckles the same as my OB? 3. If the answer to #2 is yes, than is worth while to swap the whole knuckle with lgt parking brake? 4. If I swap the rk what bushings should I replace. 5. Should I take a wire wheel to them and clean them up? 6. If yes to #5 what should I do to prohibit rust? Link to comment Share on other sites More sharing options...
